Repairing & Replacing your Honda Element's power Passenger Side Mirror
 by oklacalit
Step 3: Test & VOILA
 After I set the plastic cover back on in the inside, I started the car and sure enough the mirror works great.
If I have to do this again I'll be extra careful not to lose the nuts as I take them off, they could easily fall between the door frame and another piece of plastic and that would be a bad thing.
donc143 says: Oct 29, 2009. 7:32 AM
 I did this job yesterday.  It went perfectly.  Thanks for the help.
Oh, If you roll down your window ahead of time, it makes it easy to hold the mirror in place as you place the first (top) screw on which will hold the new mirror on as you carefully place the other 2 screws.  Also, there is a little tab at the bottom of the electrical plug.  When pulling out the plug, squeeze the tab and pull.  It releases the plug easily that way.
I bought my new mirror from www.discountautomirrors.com.  I paid $60.79 delivered, for a passenger side powered mirror.  It was just like the factory one.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
