Step 2Careful with those cables!
Go read the comments on my other Instructable on the NDS, most of them are bemoaning troubles with cables. If that's insufficient to warn you into caution, you'll well deserve any messes resulting from carelessness
Carefully open the console up, and push gently on the bottom screen to free the PCB. 'Flip' the PCB over, so that you can see both the bottom LCD, as well as the top LCD.
Watch the buttons! Putting spilled buttons back is fairly simple, but you might as well avoid it if possible.
Now, there will be two ribbon cables readily visible, and one more little one slightly hidden. One broad cable, and the little cable are for the bottom LCD, but the remaining broad cable is the one linked to the top screen.
If you are replacing the top LCD and/or shell: you will need to unlatch one of the big ribbon cables (the one nearest to the hinge), but leave the other two alone.
If you are replacing the bottom LCD and/or touch screen: you will probably want to detach the bottom LCD + touch screen cables, but do not touch the big ribbon cable that's connected closest to the hinge.
For unlatching the two larger cables: there are two beige plastic connectors linking the cables to the PCB. See the narrow black plastic bar lying across the ribbon cable? Carefully wedge your fingernail in, under the black latch, from the cable side and then gently pry up. If you use a screwdriver to do the prying, be extremely cautious not to damage the plastic, as any misalignment of any of these cables will render the console rather useless.
Refer to the diagram for a simplified illustration of this procedure.
For unlatching the small cable: Flip the PCB over so that you cannot see the screen, and turn the console so that Slot 1 (the hinge edge) is towards you. Slightly to the right of Slot 1 is a tiny cable connection (the cable is about 2mm wide). See the tiny black latch? You will need to carefully flip it towards you. You will probably need to use a flat-head screwdriver or tweezers.
Refer to the diagram.
Again: BE CAREFUL when dealing with these cables.
They sell them on EBAY or through this site to buy factory direct.
http://my.farnell.com/jsp/search/productdetail.jsp?sku=1355736
You need some soldering experience to fix that one.
The black wire just above "that" is a push fit. If you can identify another white cable with the same type of receptacle at the tip. The black cable should be attached in the near the vicinity of the connection of the white one. It should be connected to the little circuit board that is mounted on top of the motherboard.
