Repeater/Forever Circuit
Published
Introduction: Repeater/Forever Circuit
In this tutorial, I will show you how to make a redstone circuit that turns on and off. It could be used for a strobe light or anything you want to switch on and off repeatedly.
Step 1: Supplies
You will need:
6 stone blocks
1 sticky piston
1 lever
redstone
1 lapis lazuli block
1 redstone repeater (optional)
Step 2: Base and Redstone
Place the stone in the pattern shown above. Then place redstone on the stone as shown.
Step 3: Adding the Lever and Piston
Place the piston and lever as shown. Click the lever to check if the sticky piston is connected to the redstone correctly.
Step 4: Adding the Lapis Lazuli
Next, place a Lapis Lazuli block on the sticky piston, like so.
Step 5: (Optional) Add the Repeater
Place a repeater in the back to be able to control the speed.
Step 6: Finished! Test Your Circuit! :)
The sticky piston should extend, which turns off the circuit, which makes the piston retract, which makes the curcuit turn on, which extends the...... and so on.
There is a possibility that when you turn off the circuit, the Lapis Lazuli block will stay over the redstone. (As shown above.) If this happens, just destroy the Lapis Lazuli and re-place it back on the piston.
If you liked this instructable, please leave a comment down below, and vote for it in the Minecraft Contest! And be sure to check out my other instructables! Thanks!
    • Planter Challenge
      Planter Challenge
    • Pets Challenge
      Pets Challenge
    3 Comments
    I could see this used as an internal clock on an advanced redstone circuit. Do you know what the actual frequency of the wave is?
    I dont happen to know, I'm actually teaching myself redstone and commandblocks right now. Just sharing what I've learned and made.
