3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Replace Any Battery Cover
Ever drop a TV remote and break the battery cover? Don't worry. It's easy to make a replacement. All you need is some scissors, paper, and a piece of plastic. I used the side of a soap container.
For my fix, I needed a battery cover for my old Casio CTK-450 keyboard. I've had it since I was three and I've probably been missing the battery cover since I was four.
You can use this technique to replace any battery cover that uses the tab and clip design.
Step 1What's Missing?
What\
Look at your remote/electronic doohickey and imagine the cover that used to be there. If you still have the broken piece, that's even better. Now hold your paper up to the void and trace a pattern where the original cover would go. Be sure to include the main plate, any fixed tabs, and the flexible clip.
2 comments
Dec 19, 2010. 7:50 AM_soapy_ says:
I'm a little confused - how do you make the bit that actually latches the cover closed and keeps it there?
That's the bit I've never managed, and without one, it will just fall out under the weight of the batteries.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
52
Author:JamesRPatrick(Check out my blog!)
Currently pursuing a degree in Mechanical Engineering. contact: jamesrpatrick(at)yahoo.com
