Replace Broken Samsung Note 3 LCD Screen
608
7
Posted
Introduction: Replace Broken Samsung Note 3 LCD Screen
This guide shows how to remove everything from the display assembly.
more note 3 replacement parts at jinstechll.com
Step 1: Remove the Rear Case
Insert the plastic opening tool in the gap between the rear case and the base of the phone.
Twist the plastic opening tool.
Step 2: Remove Case From the Base
Slide the plastic opening tool along the edge of the rear case.
Lift the case gently from the base.
Step 3: Battery
Insert the plastic opening tool into the small gap between the battery and the phone base.
Lift the battery out of its placeholder.
Step 4: S Pen
Place your fingernail in the groove of the stylus pen.
Pull the stylus pen away from the phone.
Step 5: Unscrew Back Chassis
Remove the twelve 4mm Phillips #00 screws from the back chassis.
Step 6: Remove Back Chassis
Insert the plastic opening tool into the Stylus Pen placement holder.
Lift the plastic opening tool so that the midframe separates from the base.
Step 7: Screw Removal
Remove the single screw beside headphone jack.
Step 8: Unfasten Clips and Cable Connectors
Use tweezers to remove both antenna clips.
Use tweezers to unfasten seven cable connectors.
Step 9: Motherboard Removal
Pull up on the motherboard with tweezers.
Step 10: Spudger Tool Placement
Insert the spudger into the headphone jack.
Step 11: Lift to Separate Headphone Jack
Lift the spudger to separate the jack assembly from the motherboard.
Pull to remove.
Step 12: Metal Bracket Removal
Remove the metal bracket located in the top left hand corner.
Step 13: Remove Vibrating Motor
Remove the vibrating motor by pulling up on it carefully with the tweezers.
Step 14: USB Port Removal
Lift USB port from the front assembly using the tweezers.
Step 15: Display Assembly
You are now left with the display assembly.
Step 16: To Reassemble Your Device, Follow These Instructions in Reverse Order.
    • Spotless Contest
      Spotless Contest
    • Space Challenge
      Space Challenge
    • Science of Cooking
      Science of Cooking
    2 Comments
    Do you have instructions to put the new screen in?
