Replace LCD Backlight Inverter on Any Monitor for
Step 1
27 comments
May 25, 2009. 6:53 AMsimsfan999 says:
Great turorial, i only have one question - Do the brightness controls still work with this method?
Apr 18, 2009. 9:08 PMdropfry says:
Is it possible to restore original brightness control through relays? How would you go about doing so?
Mar 15, 2009. 7:12 PMbdknocks says:
I just did this for my 10.4" touchscreen in my car. Worked great, I only needed one inverter. I had all the wires backwards the first time and it didn't fry, after I got them right it was nice and bright. Thanks
Feb 22, 2009. 1:52 PMdocstrangelove says:
Very good job guys! With this guide a old dead monitor return to life! This is my experience So i find at only 9,90 EURO a kit for pc with neon cold cathode and inverter (just like I've seen in thi sguide) for a desktop pc. First for the power to inverter I use the original cable, go down insiede my desktop pc and work pretty well but...only for 5 hours! Damn, i retry with 2 inverter, one form a transparency adaptor of my old scanner and another from a fan with neon...and 12 hours later is functional! I assumed the problem of my first inverter is too cheap ad the eat on the monitor plastic chassis damage the inverter, already now my monitor as 1/2 pastic chassic and the eat is dissipate quiet good... :-)
Nov 27, 2008. 5:39 PMlinfongyu says:
My HP Laptop's monitor is flickering intermittently. It's only 2 years old. I wonder if it's the backlight or the inverter. Can someone help me diagnose it? A new LCD part cost $120, the inverter, $15.
Symptoms:
1. If I use the function keys to dim the LCD brightness to about 50%, the monitor "usually" will not flicker. But it is very hard on the eyes since it is a bit dark.
2. If I turn the monitor to full brightness, as I like to since it's easier on the eyes, the flickering is intermittent. When it does act up, first the sections of the screen flicker horizontally to black, on and off very quickly, then eventually goes black altogether. But I can still see the inprint of the page in the background.
Any ideas? Thanks in advance for your help.
Nov 1, 2008. 10:50 AMFozzy Vis says:
"found a labeled power wire running +12VDC to the main monitor board. I momentarily pulled that to ground and found about 3.5 amps"... I'm wondering (since the only electronics knowledge I have is coming from reading stuff), is this a good/correct/safe (for the powersupply) way to find out how much power a certain component can give? I'm doing the same thing as you did on the instructable and am in the process of looking where to tap power from as well.. It seems like a logical way of finding out, I'm just figuring it's pretty much the same a short circuiting a circuit, no? thanx for the instructable!
Nov 1, 2008. 4:23 PMFozzy Vis says:
Oh OK, I thought you actually meant you shorted the wires - without a resistor in between and a current meter in series...<br/>So what you do is put in a resistor, measure the voltage drop over it and calculate I = U / R the current going over it? Would that be the maximum a certain point in a system can provide? Sometimes there simply isn't a datasheet to be found :)<br/><br/>I'm now looking at an old inverter from another lcd (laptop), and mine. Both have more then just ground and positive going to them, need to find out which is which (probably an enable line and light control, which would need either +3.3 or +5V)... Some of the wires are doubled (like ground and positive), the others need some more investigation. Or I might end up just buying new inverters, like in the Instructable...<br/>Maybe I'll first start off building a bench power supply off an old ATX power supply to get started, think it might come in handy after all :)<br/><br/>But thanx again for the instructable!<br/>
Sep 10, 2008. 5:48 PMthyubernoob says:
Thanks Waterppk, My monitor is stating to flicker and is dimmer...looks like it's time to replace some ccfl's....thanks for the info.
Aug 26, 2008. 5:31 AM1337chaos says:
very good tutorial. i'll definately be using this tutorial soon. one question: is it the same for every monitor? do i absolutely need 2 inverters every time? theres no way i could screw up and blow the bulbs is there?
Aug 26, 2008. 8:23 AM1337chaos says:
ok awesome :) im looking at something within the 19" to 22" range to do this with. so they'll probably have quite a few more bulbs the higher you get up there dont you think? nice to know i cant damage anything also. im usually pretty good with electronics, so i doubt i'll screw it up, but just in case ;) thanks for the fast reply, hopefully i'll be able to follow these instructions in a few days and see if i can fix some monitors! PS: i cant believe that the cathode kit is only $3 but the shipping is $7 :P
Aug 21, 2008. 7:21 AMboognishmofo says:
I have an old toshiba satelite that had a broken screen. I used it for a while hooked up to a external monitor. I recently got a new satelite that had a fried board from a friend. The wires are a little different but is there a way to swap the screen to the one that works. Is there a color code for what wires are what.
May 6, 2008. 2:58 AMbigtank2385 says:
i recently bought 5 defunkt 17" lcd's from my local computer recycle store. they are CTX business models, nice ones to, i think there only about 2 years old. they each had "no power" written with crayon on the top of the bezel just above the screen. So i thought they don't actually open them up and check, so, i assumed it was the inverters. (each has two bulbs) So they let me plug each one up and check for myself, i could see the on-screen menu on each one, but no light, so i knew it was the inverters. he let me have all 5 for $40 (8 bucks apiece, what a deal!) I've got one to work, witch im currently using now, by swapping the inverter out of a REALLY old lcd (1999) he let me have about 3 months ago. ironically, the plugs were the same and it's worked for a week now, the other four, i will use this instructable and get them all working. (i have dual nvidia cards, up to four monitors)! This will save me a ton of money.
Mar 24, 2008. 2:01 AMt.rohner says:
Nice instructable but in step 4, the distance between the primary and secondary side should not be made smaller by putting screws there. I'd rather fix the supplies with double sided tape (3M red) or hot glue. Otherwise really good idea.
Mar 23, 2008. 9:13 AMthearchitect says:
Great instructable, very insightful, but didn't work for me when I did the same thing last month (to repair 6 CCFL 20" monitor) . It worked for a few minutes, but later the LCD flickered and smoke came out from back of the monitor. It may be because there was a short somewhere since I didn't have the proper connectors to go with HV bulb ends. BTW, I think LCD monitor CCFLs run at about 900V, but computer case CCFLs run at about 690V. I may be wrong, but this may be another reason that my experiment ended with smoke and stink. Good luck! Koray.
Mar 23, 2008. 4:03 PMwestfw says:
Hmm. I "fixed" a laptop LCD once where the original inverter was still fine, but the actual CCFL tube had gone bad (it was very dim and "pinkish", and things got better when I replaced only the tube.) I wonder if there are any good (read "easy" ) ways to figure out which pieces are broken before you start trying to fix them?
Mar 23, 2008. 1:59 PMErik Lindemann says:
Woohoo! I have an LCD monitor that died last year, I kept it in my closet since I knew it was something stupid like this. I'll have to go fix that and get some dual-monitor action going on.
Mar 23, 2008. 1:58 PMthinkahead says:
I have a Sony Vaio that only had a bad connection. It looks like Sony crapped out on gold or silver plating for the ribbon ends and used tin instead. I'd open it up, disconnect and reconnect and within a few days, weeks or months, especially after storage same thing again. I tried using silicon spray to keep the air away from the connections but finally had to use silicon grease. I just coated the contact side of the ribbon connector so it would still be hard to completely dislodge but now it hasn't given me any problems for almost a year. I was wondering what I would do if the inverter ever went out since there probably isn't a laptop with more expensive replacement parts. Now I'll be able to fix my laptop if the inverter ever goes out and fry a few bugs in the meantime while I'm waiting, especially kitchen ants. :}
Mar 23, 2008. 1:07 PMGorillazMiko says:
Pretty cool! +1 rating is all I need to say. ;-)
Mar 23, 2008. 12:34 PMmrbob1000 says:
i use those inverters for stuff like... lighting wood on fire, zapping dead bugs (one time... the bug came back to life!) making big blue sparks... if you remove the old bulbs and completely replace the bulbs and inverters i think you will do better.
Mar 23, 2008. 9:11 AMa grain of alt. says:
Fantastic work- DIY repairs with substituted parts to save money are always awesome! Thanks for this!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:waterppk
I'm working on my Master's of Science in Mechanical Engineering, specializing in Engine Research at the University of Wisconsin - Madison. ***All Instructables Projects moved to my personal site, I di...
more »
