3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Replace Low Voltage Bi-Pin Halogens with LEDs
This Instructable details how to easily retrofit a low voltage (12V) bi-pin halogen fixture with a high power LED "bulb" that will use less power (<10W), last longer (50,000 hrs), and give approximately the same light output (~300 lumens). This type of fixture is most often used as an accent light or focused task or down light such as display cases, reading lights, desk lamps, and over-island pendants.
This Instructable is similar to some of my others (see links below), but represents the latest efforts to increase ease of integration, low cost, and practical use of ever cheaper high power LEDs. With each iteration, the roadblocks to using LEDs in real residential applications are reduced.
http://www.instructables.com/id/Practical-LED-Lighting-for-Fun-and-Profit/
http://www.instructables.com/id/High_power_LED_bike_head_light_with_integrated_hea/
Step 1Tools and Materials
Tools and Materials
The materials that go into an LED lamp are the key to its performance, long life, and ultimate successful replacement of a traditional incandescent or halogen bulb. The most important item is the heat sink and has proven to be the hardest part to find in a format that is compatible with the candidate light fixture. Many heatsinks are out there but few have been designed with a circular art glass shade in mind. Recently I came across a part on Digikey that was designed for powerLEDs, had the size and flexibility to integrate into a conventional light fixture, and was cheap enough to consider.
The other key components are obviously the LED itself and the drive circuit. There are a lot of high output LEDs on the market, but for residential lighting, pure output is not the most important factor. The highest efficiency and highest output LEDs are "cool" in that their output is very blue and not appealing for general illumination in your home. This is often indicated by their color rating, given in degrees Kelvin. Cool white is in the 6500K range, with neutral white in the 4500K and warm white in the 3700K range. The problem for LEDs is that the mix of phosphors used to get warmer and thus more appealing light output become less and less efficient. So a top of the line cool LED might output 100 lumens per Watt while the best warm white LEDs would be in the 60 lumens per Watt range. Bummer.
After endless hours searching and purchasing various LED components I used the following parts to build a practical and relatively cheap halogen replacement for my over-sink kitchen pendant. I used a Philips Rebel 3-LED star. Many people prefer the Cree XR-E line of LEDs, and some of the Cree LEDs do have higher specs. However, the size of the Rebel allows 3 of them to be placed in close proximity which is critical for replacing a small bi-pin halogen. I used a driver circuit from DealExtreme, which ships direct from China.
Tools and Materials:
Heat Sink, $3
Bi-Pin Drive Circuit, $2
Rebel 3x LED star, $15
Thermal Compound, $7
A scrap of wood
Hot glue
3 Small screws (e.g. 4-40)
Drill bit and tap to go with screws
Solder and wire and the will to use them
Total cost is about $20 bucks if you have the thermal compound and screws on hand. This is far cheaper than in the past. Woot!
38 comments
May 27, 2011. 9:00 PMrobert.d says:
We have bought a lot of G4 Led Bi-pin halogen bulbs from the hero led store. They have a wide range of halogen led replacements bulbs.
Sep 22, 2009. 4:06 PMElChadwick says:
I'd like to do this for a light that runs GY8.6 75W 110-130V hallogen bulbs. Do you think it's possible or practical? What would I need to do in addition to this protocol?
Aug 3, 2009. 12:28 AMpeterlonz says:
Something seems not to add up here: A typical halogen is about 50 watts & its efficiency is not hugely different to LED's as (I understand things), as for example a compact fluorescent is, being 3 to 4 times as efficient as a halogen. So how on earth can an array of three LED's, total 10 watts, be anywhere near the light output of the replaced halogen ?
Jun 21, 2009. 11:57 PMjames.mcglashan says:
y not just use this on a bike with a bike generator????????
Jun 19, 2009. 5:29 AMrasbazz says:
There is a really cool looking heatsink available that is for LED stars to be mounted to. The picture is only different from the ones I have purchased as they came Black Anodized(Way cool, has a Star Trek-Klingon kind of thing to it). This one is 12.7mm Height, 70.1mm Diameter and a bit under three bucks. Also available in 35.4mm, 50.8mm and 76.2mm H., all 70.1mm Dia. Largest is above nine bucks. I'm about to use them for flashlights but am having a small artistic brain freeze design wise as I want them to be exposed because of their unique aesthetic appeal. But as you can see there are a number of mounting options and multiple emitters is what I am trying to make happen so bolting a number of them together won't be a problem. Lux Overkill is what I have appropriately named this project and it does have a certain ring and truth to it don't 'cha know. I am not sure is it is allowed to post the retail outlet site that I got them from in this forum but it's all in good fun and building stuff so here goes. Hope this helps out. Newark.
Jun 19, 2009. 8:49 AMrasbazz says:
Your Welcome. These are really interesting in that they can be stacked so if one isn't quite getting the job done no need to even pull the star off. I have 6 of the 12.7mm and 4 of the 35.4mm purchased five or six weeks apart and the manufacture is perfect. Running wire is a cinch and easy to hide. With a bit of felt on one side make table coasters that gets noticed like you wouldn't believe and the best serving trivet ever. I put three 12.7mm into a trivet as a joke but after adding rubber chassis box feet rather than felt turning it machine washable... Never thought I'd see the day a heatsink would get me excited. Go figure. >:)
Jun 18, 2009. 4:51 AMbadpauly says:
Any idea if the bi-pin drivers can be found (or modified) to run off 6v?
Jun 15, 2009. 2:00 PMe_lectro says:
Do you need a heatsink that large? I thinking about using these for cabinet lighting and something that large would be hard to hide.
Jun 18, 2009. 5:05 AMJarl says:
If anything, you need a heatsink larger IMHO. The cooler they are, the better LED's run (and 50,000 hours is only when kept cool- overheated, you'll be lucky to get 1000 hours). Passive heatsinking (no fan) will require a very large heatsink. If you can find a small, quiet fan, then you could use an active heatsink- the fan rigged to the smallest CPU heatsink would be sufficient to keep the LED's running nice and cool. The cool thing about LED's is what they can if integrated properly- i.e, water cooled with the water that's entering the water heater. Now that'd be pretty swish : )
Jun 15, 2009. 4:50 PMosgeld says:
what about using a old cpu heatsink
Jun 16, 2009. 7:17 AMe_lectro says:
Those heatsinks might not work as a typical bulb replacement because of the shape, but how much surface area do the leds need at this current? I went to the data sheets, but all they said was you should use something and there will be more info here later.
Jun 17, 2009. 7:14 AMbananafred says:
You might actually be able to use one of those mini 12v blowers instead of a heatsink, or along with a TO-220 chip heatsink stuck to the back of the star.
Jun 17, 2009. 2:02 PMbananafred says:
Size? You can find very quiet, tiny fans for pretty cheap.
Jun 18, 2009. 7:14 AMgeek65535 says:
Your best bet is a fan from a laptop. They are tiny, and generally have integrated heatsinks.
Jun 16, 2009. 2:01 AMomnibot says:
Sounds ideal if you can fit all the parts in. Prolly not difficult if you dremel away some fins in the middle.
Jun 16, 2009. 9:03 AMosgeld says:
well i was thinking more along the lines of OLD intel pentium oem sinks, or something found on a amdk6/2 or penitum 3, where the footprint is ~ 2 inches square and ~an inch tall
something like http://content.etilize.com/Large/11395738.jpg
not a huge modern one
Jun 16, 2009. 2:01 PMomnibot says:
That should be even easier.
Jun 18, 2009. 5:22 AMDaddio_UK says:
I always find the colour of the light from LED's isn't particularly nice on the eyes. maybe its just me?.
Jun 18, 2009. 5:44 AMblazingpencilsdotcom says:
Thanks, cool instructable. What is the color temperature in this setup, I gather its the bluish light , 6500? and if we wanted the warmer light it would throw off 2-3 times the heat? Can this be dimmed?
Jun 18, 2009. 8:30 AMCameronSS says:
According to the website to which he linked in the Materials step, it's an average color temperature of 3000K.
Jun 18, 2009. 6:03 AMSpokehedz says:
Your best bet there would be to use a yellow filter over the light. I personally like the white glow of the LED's, but I can see where some people wouldn't like it.
Jun 16, 2009. 2:47 PMdchall8 says:
Here's another heat sink idea from Instructables.
Jun 15, 2009. 11:37 AMnaruto the ninja13 says:
do the provide the same light radius as a CFL? and also these are mainly for celing fixtures beacuse the only light up on 1 side right?...
Jun 16, 2009. 11:24 AMshamanwhitewolf says:
What about the possibility of increasing the reflectivity of the inside of the lamp shade (chrome or other shiny paint) and mounting the LED package up-side-down? That might increase you dispersion some, but it also might increase the smoothness of the dispersion, making it more even throughout its dispersal pattern. Maybe.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
124
Author:jmengel
