Step 4Solder the drive to the LED and mount to heatsink
Solder the wires to the star, making sure the + and - driver and LED wires match. You should briefly test the LED now with a power supply or battery. You'll need 12VDC or greater, less than 30VDC or so. Check the specs if in doubt. Don't leave the LED lit for too long without it being mounted on the heat sink or you can damage or destroy it. It gets hot fast and you know what they say about a race car in the red. The bi-pin driver is capable of operating regardless of the input polarity so don't waste your time looking for which pin is which.
Satisfied that everything is working, apply some thermal compound to the heat sink under the LED and then apply the LED. Insert and tighten the 3 screws, taking care that they do not short out on any of the wires or pads on the star. Once fully seated, use your multimeter to test for shorts.
Add Comment
