Replace RAZER DeathAdder's Microswitch and LED
7,680
Posted
Introduction: Replace RAZER DeathAdder's Microswitch and LED
Step 1: This Is for 3500 Dpi Version(not 2013)
The products produced after 2013 may have some differences but it's similar at most parts
Step 2: Careful!
Be careful with ribbon wires. it's fragile and if you have broken these you must fix it with a
Step 3: That's It
Step 4:
Step 5: Then Let's Add LEDs
I don't know why they put so many holes here, but I like it.
Step 6:
Let the LEDs go though the hole beside the old blue LED. Don't forget to separate two pins of LED
Step 7:
If your new led's voltage is lower than then old led's which 2.7v. You must add a resistance. I used 1k resistance. You can change luminance by using different value of resistance.
Step 8:
Add the LED and the resistance into original circuit. Be careful with direction.
Step 9: The Final Step
Don't forget plug the header
    • Microcontroller Contest
    • Spotless Contest
      Spotless Contest
    • Science of Cooking
      Science of Cooking
    Hi there is any alternative pin for scrool led? I've just solderd out by accident pods from pcb
