Introduction: Replace Stabilizer on a Cut Throat Razor
Picture of Replace Stabilizer on a Cut Throat Razor
I found two cut throat razors today at the local flea market from a nice old man.
One of them hade a really cool eagle design on the stabilizer but completely rusted through and the other had a good blade but a bit boring stabilizer. I will in this instructable describe how to remove a stabilizer and replace it.
Tools and material you need:
A brass pin/nail or rod to attach the new stabilizer (I used a nail that is used to put up pictures on the wall that had the size)
Dremel to remove the head on the pin that holds the razor
Hammer
Nippers
Step 1: Remove the Pins and Razors
Picture of Remove the Pins and Razors
Use your dremel tool to remove on of the heads that attaches the razor. Then use a thin blade or something similar to carefully remove the razor from the stabilizers.
Step 2: Attach the New Stabilizor
Picture of Attach the New Stabilizor
Use your brass pin and attach the new razor to the stabilizer. Cut it so it sticks about 1-1.3 millimeters up.
Then you just hammer on the side you cut so that it forms a head on the pin and are as firm as you like it.
You're done! It takes about 10-15 minutes in total, if you do like me and take a coffee break in the middle.
DIY Hacks and How Tos (author)2016-08-28
Nice restoration
Thank you!
About This Instructable
285views
3favorites
More by djakobsson:Replace Stabilizer on a Cut Throat Razor
Add instructable to:
