loading
Step 5: Test it
Boot that thing up and tap some keys.
Mine needed the time and date reset as well but I'm not sure if that had anything to do with the keyboard swap. Not sure why it would have.
Either way, it made for a good test of the new keys since it required the use of numbers.
If things are working just button it up! The plastic cover just snaps back in.
<p>Some facts and other points mentioned here are quite considerable and to the point as well, would be better to look for more of these kind for efficient results.</p><p>http://www.hpservicecenters.in/</p>
<p>Thanks...</p>
<p>Thank you very much.</p><p>It's very useful to me </p>
<p>I have the Toshiba C55t-A5218. I couldnt get windows to come up, but later did. However when the laptop was doing a restart, I heard a pop (not sure if it was laptop or something else) and now it wont power up at all (with adapter or battery. Any suggestions. The adapter is producing 19 volts. Please help, or I have a boat anchor. </p>
<p>Hi, In my Toshibha Laptop one of the key has been broken and I got the Original key from: <a href="http://www.replacementlaptopkeys.com/servlet/the-19917/Toshiba-A600-Laptop-Keys/Detail" rel="nofollow"> http://www.replacementlaptopkeys.com/servlet/the-... </a></p><p><a href="http://www.replacementlaptopkeys.com/servlet/the-19917/Toshiba-A600-Laptop-Keys/Detail" rel="nofollow"><br></a></p>
You are correct that Toshiba keyboards are pretty much universal between most of there laptops. You can find Toshiba keyboards at very cheap prices here: <a href="http://www.zkarlo.com/toshiba-laptop-parts.php?brand=Toshiba&part=Keyboard" rel="nofollow">Toshiba Laptop Keyboards</a>
That is very good job. if you want to find a replacement part for your toshiba laptop you can get a replacement at <a href="http://www.laptopparteshop.com" rel="nofollow">www.laptopparteshop.com</a> with low price.
Nice writeup. Hooray for Amazon and replaceable keyboards :D
I tried replacing my toshiba keyboard, bought off ebay from china using the computers model number and the full model numbers off the bottom of the old keyboard. <br>I was sent a keyboard with near matching numbers, but the ribbon cable was to the left by an inch (guessing to remember), so not usable. <br>Sent it back, emailed them megapixel pics with measurement photoshopped in. <br>They sent another, better matching numbers, still same offset cable. <br>Sent it back, more detailed pictures, they sent another, numbers matched perfect, same problem but the ribbon had copper corrosion. <br> <br>They refunded my money less initial shipping I paid and to send them back, and let me keep the last useless keyboard. <br>I had to buy a used DOA computer replacement to fix the problem. <br> <br>Take what you will from this experience. <br>
thank for your advance it's an experience for me to read this
Wow... that's terrible! I just looked up my model number and found one on Amazon. Had no trouble at all first time around. Though for unrelated reasons and another known issue with these, my screen has gone so dark I have to use an external monitor.<br /><br />
For the new 2010 models, the keyboard is easily removed by removing the cd drive, and unlatching from the underneath.<br><br>see: https://www.instructables.com/id/Toshiba-satellite-disassembly-overclocking-full/<br><br>Not finished yet, but the disassembly bit is done.
If you needed to add the time.. then the CMOS battery was dead. cna also be replaced normally with a little more break down. Usually happens if you have had it unplugged for long periods of time and not being used.. Great write up.. when you clean things out. while open.. make sure you get all the vents also..
Hey , thanks!
if that batterie's dead, then it's a really old laptop :P those things run for years most of the time. nice instructable, with clear instructions/photo's :D might want to add a site where alot of instructions are found<br> i found <a href="http://www.insidemylaptop.com/">this</a> site usefull<br>
Thanks for that link by the way. I just Googled Toshiba laptop breakdown guides when I did mine. There were a lot of them. The one problem I had with them was they "all" seemed to want a much more complete tear down that wasn't needed to replace the keyboard. I would have needed to remove more than a dozen screws for no reason if I had followed any of them.
It is a really old laptop! I just can't let it die. I think the screen is going dark now though. I'll have to see if it's the board or just the cathode going out. If it's the board then it's pretty much dead and the HD will migrate to an external enclosure but it's just the monitor I'll be replacing that or trying out the LED retrofit solution.
About This Instructable
119,555views
25favorites
License:
More by Culturespy:Carve a bone needle for naalbinding 9 Volt battery adapter for Arduino Cure your own olives
Add instructable to:
