---IMPORTANT NOTE: This procedure is much more complicated than replacing the battery in a modern system. Please read through the entire Instructable before starting. Also, this repair is designed to meet the original factory specification for this computer. If you just want to change the battery–and don't mind slightly changing the appearance of a rarely-seen area inside the computer–then there are much simpler options. See "Alternatives" at the end of this Instructable.
Remove these ads by
Signing UpStep 1Supplies
–Replacement battery, 1/2AA, 3.6V, axial leads. (Tadiran TL-5101/P)–Digi-Key, www.digikey.com, P/N 439-1003-ND
–Soldering iron, 20-40 watts, fine tip–Radio Shack
–Solder, 60/40 tin-lead–Radio Shack
–Desoldering bulb, wick, or pump–Radio Shack
–Screwdrivers
NOTE: DON'T substitute other battery types. Most seemingly similar batteries (even with the same nominal voltage) won't work properly, may damage your computer and could even pose a fire hazard.
Add Comment
