Replace battery in Nike+ sensor for under $5
Step 1Disassemble the chip
Use your knife to pry apart the side of the chip. Then use a small screwdriver to remove the 2 screws on the top.
11 comments
Mar 20, 2010. 2:26 AMveliki says:
worked like a charm, just finished two sensors. had to weld the red wire on one of them, but everything worked fine on the other. used the sharp blade knife to CAREFULLY cut the sensor open.
Mar 27, 2010. 2:12 PMEndoTM says:
I broke the red wire from the chip. Is there any idea how to attach it? It seems its too small to be soldered.
Oct 18, 2009. 11:07 AMsteph1978 says:
you got a magic knife, I can't manage to open mine.
I broke a cutter blade and just damage a bit of the plastic with a good knife.
I afraid to cut myself if I insist cause it is not easy to have a grip.
Oct 6, 2009. 10:47 PMRyan_Brantley says:
I just opened mine up in less the 5 minutes by a actually cutting it open with a small razor blade by rotating it back and forth on the rounded ends until I could work my way all the way around the sensor.
Aug 29, 2009. 12:01 AMBisquick says:
That first picture of you with the knife cutting towards your other hand reminds me of something similar I was cutting last year; turned out that cutting TOWARD yourself is unsafe especially cutting something that might give way, and once that baby slips you will get 20 stitches. I had about half of my thumb reattached (longways) using a dull knife. I suggest learn from my mistake and hold the sensor with a vise or use a different non sharp tool. Otherwise great idea!
Aug 31, 2009. 7:21 PMaqwiz says:
honestly not cutting towards yourself in any fashion is good advice, but I believe he is simply using the knife as a wedge, kinda like you would a butterknife to unseal a frozen jar lid, in which case there is a lot less likelihood of slippage, and more cautious finite control over the tool is being used anyway due to the shorter axis of rotation that comes from twisting the blade into the area between the plastic pieces, as compared to a cutting arc when digging through tough plastic, or sawing at it.
Apr 4, 2009. 2:02 PMRaDragon says:
Anyone know what tool he's using as a saw in this video?
http://www.youtube.com/watch?v=2E1ufxNG6zc
His work looks very clean and definitely no knife boo-boos!
Apr 4, 2009. 2:48 PMRefriedNoodle says:
it's a jewelry saw
Mar 30, 2009. 6:56 PMLeo Bley says:
I used a vice to hold it, then i used a box cutter with a new blade to repeatedly score the seam between the orange and white layers. I found light, controlled, repeated scoring allowed me to open it up after about 30 minutes... and I didn't cut myself!!;-)
Feb 11, 2009. 5:12 AMdearannie says:
I tried prying it with a knife for half an hour before I sliced my thumb open very seriously (i might need stitches), then it took my brother another 10 minutes to get it. I think advising people to pry it open with a knife was a bad idea. My brother ended up using a screw driver to drill very carefully into the seam and then pryed it with a flat head screw driver.
Dec 26, 2008. 4:55 PMjklivin29 says:
It worked!!! I was amazed. And it wasn't very difficult.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
14
Author:pickingrin
