Replace battery in Nike+ sensor for under $5
Step 3Attach the new battery
Now attach the new battery just like the old one was attached making sure to put the - and + terminals on the correct sides, add a little electrical tape to secure it all in, put in the screws and put the top on. Then use a little super glue around the edges and your good to go!
Let me know if I missed anything, and please rate!
Happy Trails!
NOTE: Thanks to manubx for fixing the low battery screen on iPhones and iPod Touches!  Check it out at  www.instructables.com/id/Nike-sensor-battery-replacement-get-rid-of-the-Lo/
17 comments
Dec 28, 2010. 2:06 AMbhaveshpandey says:
heyyy .. i installed a new battery on2 mah sensor n it worked az d sensor waz detected on mah ipod but still during mah workout,d ipod is still showin the sign wich it shows when the battery is low...!
can ny1 tel me wat shud i do...?
Jun 12, 2010. 6:32 PMtotalgeniuschris says:
Sweet dude. Worked thanks. I used selotape to hold it together afterwards and some folded electrical tape to keep the pressure on the battery contacts.
Apr 15, 2009. 4:21 PMpnpires says:
:( my sensor doesn't have any life signs. I replaced the battery. Everything went perfect. I checked with a voltimeter and there are no shorts and I have tension in several circuit points, so it should be working, But the Ipod fails to find the sensor, no matter what. Buuuuaaaaa!!!!! Any ideas? I clicked the back button to put it to sleep, wake up, etc. Nada! Rien! EOF!
Mar 24, 2010. 1:34 AMrougerev says:
 I has a similar problem but after many tries I found that if the acelerometer (the thing on the battery) is too tight (maybe for an excess of tape) the ipod don´t recognize it, the solution: let some space between the top part of sensor and the battery with the acelerometer attached, in this manner the acelerometer is not pressed and is ready for measure force and aceleration and make the calculations for velocity.
Mar 31, 2009. 10:35 AMLeo Bley says:
After adding a brand new CR2032 battery, the sensor started working again. However, the battery indicator was low (within the Nike+ program on the iPod). Is that normal, or could I have applied the connectors in such a way that it is shorting out and draining extremely quickly? There were several points during the install where a conductor could have bridged the battery's terminals for a short period of time. Perhaps, were some of those extra stickers acting as insulators to prevent certain connectors from bridging the terminals?
Jan 9, 2010. 11:00 AMgefusu says:
Same thing happend to me, indicator says low battery
Apr 11, 2009. 11:04 AMbhillyer70 says:
While removing the battery terminals I accidentally nicked a wire. I had to make sure I taped it up too (very small=very hard) maybe to cut something.
Feb 14, 2010. 4:50 PMDrixter says:
My nike sportsand doesnt seem to LINK with my sensor. any tips? ive tried linking several times but to no avail.now it cant possibly be the sensor because my kit is brand new. HELP!
Oct 7, 2009. 8:20 AMRyan_Brantley says:
Just got through with mine and it works flawlessly.  I actually broke the red wire from the small attachment, i stripped some of the wire and just taped it super tight and it works well, I took it around the block (exactly on mile) and my sensor read out .98 miles, so it is close enough for me.  Thanks.
Sep 21, 2009. 10:10 PMDarkClownMagic says:
Didn't work for me. I mean that I could not pry the case apart without destroying it in the process. Mine is very old. I bought it the same week they were released (2 or 3 years ago I think). Perhaps they glued them better back then? It's apart not, but there is no possibility of putting the case back together.
Jun 3, 2009. 7:50 PMjumpback98 says:
how did you reattach all three connect points (the green circle, the horseshoe on bottom and the red wire small attachment). Did you individually connect each of these with glue or simply put them all approximately in the right place and tape over it all with the electric tape?
Jul 4, 2009. 2:29 AMurd3b4me says:
im from the philippines. my sensor now working. i have saved a lot. im ready for my full marathon this sunday
Apr 22, 2009. 11:42 AMstasky15 says:
Muchas gracias, me ha servido mucho :D
Mar 30, 2009. 6:58 PMLeo Bley says:
Instead of super glue, I simply used electrical tape so that I could test the unit and have an easier time replacing the battery next time!
Mar 11, 2009. 2:02 PMtrentsthompson says:
This works! You have to be extremely careful and take several hours to pry the case open, then be careful inside to not cut any wires. $3.75 total out of pocket! Sweet!
Nov 16, 2008. 7:14 PMosval says:
Nice work, I did the same with my sensor but instead of using super glue, I used silicone with best results because the silicone fills the empty spaces left by the screwdriver when I tried to open it.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
14
Author:pickingrin
