This instructable does not require advanced soldering/desoldering skill. I had never desolder anything before, but was able to somehow desolder the jack.
[UPDATE]
The problem kept coming back. So I did permanent fix using modem port in my latest instructable.
Remove these ads by
Signing UpStep 1Initial Diagnostics
The new DC jack shows how it is supposed to be.
"Relish your victory now."
Just do.
http://www.laptopbatteriesinc.com.au/laptop-battery/dell/dell-studio-1537-battery
It's called a Jerkstopper. It works. The Kit comes with three different CRDs (USB, RJ11 and RJ45). Yea I know the name is "suggestive" or "funky" or "stupid" or Weird" but the device does work and stops the problem of the damage from daily tugging or pulling on the cable. www.jerkstopper.com
I decided not to even attempt to resolder it, since the previous attempts only lasted a few months. I removed the old power jack and replaced with loose 18 gauge wires that I brought out the back of the case, to which I then attached a really sturdy chassis-mount power plug.
What took the longest was taking the laptop to pieces and then reassembling it, just a long series of screws, clips and panels to take off in order.
By far the most difficult part of the process was unsoldering the broken power jack. Anyone attempting to replace a laptop power jack will most likely run into the same problem. It's hard to heat the power jack sufficiently to melt the solder where the jack is attached to the circuit board.
Just adding solder to a weak solder joint as shown in this instructable is worth a try for the first go-around, but be warned, the design itself is flawed. Power jacks should not be soldered directly to motherboards, but that's what most manufacturers do. This repair is likely to fail again. However, it is worth a try.
