the mainboard here is from friend's computer. it crashed randomly for few months and now it does not allways complete startup
this may - and in this board is - caused by failed capacitor. capacitors stabilize the power to components in the computer. when they go bad the computer gets spikes or 'flickering' voltage that makes it malfunction and damages it
Remove these ads by
Signing UpStep 1: Tools
pin from message board
sharp soldering tool 30 W (more may be better but dont overkill) and soldering stuff
Visit Our Store »
Go Pro Today »
and you need a power supply tester and a mother board pci test card they will tell you whats wrong with computer
just in case anyone wanted to know, the board did work, until the power supply i had hooked up to it literally blew out. there are no bad caps and now i dont know whats wrong with it because changing the cpu, ram, and resetting the bios dont do anything. it just keeps beeping.
a quick google search and i found the same board as i have got.
http://www.google.ca/images?hl=en&gbv=2&biw=1003&bih=583&tbs=isch%3A1&sa=1&q=pro300a_afp&aq=f&aqi=&aql=&oq=
the sticker on the bios says:
UNITY
IBM (C) 2001
REV .09
thats all i could find, let me know if i need anything else.
1 short Normal POST System is booting properly
2 short Initialization error - Error code is displayed
1 long, 1 short System board error
1 long, 2 short Video adapter error
1 long, 3 short EGA/VGA adapter error
3 long 3270 keyboard adapter error
Continuous Power supply error - Replace the power supply
999s Power supply error - Replace the power supply
No beep Power supply failure - Replace the power supply
Here you go
It is definitely coming from the speaker on-board, i am still not sure whats wrong with it yet, i am going to see if i got the model right, i might have mistyped it.
I found this site helpful: badcaps.net
Random lockups are the most common symptom as the internal resistance falls and the ripple on the power lines increases.
