Remove these ads by
Signing UpStep 1Preparing the speaker.
But if you're as cheap as I am or have little money to spend on speakers, this repair is for you. So lets get started. The Victim for this job is a nice JBL 10" subwoofer. First, remove the speaker from the cabinet. Secondly, gently remove the old surround from the cone. About 90% of the speakers I find use foam. This stuff usually just crumbles away. This speaker is a bit nicer and uses rubber. This speaker as many others has thicker foam pieces glued over the top of the edge of the surround.They typically come out in several pieces. Use a knife of some sort to gently pry them off. Then pull the rest of the surround off.
The next step is probably the most tricky. Making the new surround. See if you have any old scraps of cloth laying around. The best cloth to use would be a synthetic blend, tightly woven, and smooth.I've used all sorts of cloth, including canvas.But you want to use something that's flexible enough to allow the cone to move freely. Use the speaker to trace the shape of the surround to fit. Secondly, measure how far in the surround reaches towards the center of the cone. Usually the surround glues to the very edge of the cone. But since you're using cloth, you will want a tad more holding power. So measure inwards about 1/8" from the outer edge of the cone. Use a compass to mark the inner part of the cloth circle to cut out.
Once you've cut the surround out, you will want to make slight compound cuts all along with edges of the cloth, about every 1/2" or so. You do this so the cloth won't crease or wrinkle as it is being installed.
Anyway, the speaker I repaired in this post has been alive and kickin' ever since the repair. Over and Out.
This instructable has given me a summer project for after exams. I look forward to trying it. Thanks man; I'll let you know how I do!
i just looked up 'felt' and it is 'non-woven', so it may not be appropriate, eh? but what speakers did you use canvas on, eh? tent or tarpaulin grade? def not flexible.
back in the day (dont know bout today) mfrs used rubber or foam... for a reason,eh?... trade-off between durability and expense vs. flexibility and rigidity... (i assume both rubber and foam are effectively impermeable... )
flexibility and rigidity seem to be the essential characteristics, and it is a balance point. Too rigid, the cone doesnt move, too flexible, it moves too much in unwanted ways... Trying to achieve the balance (of control of the movement of the speaker cone in the 'in and out' direction, without any side to side, with 'free movement' of the speaker cone in that direction.)
Your description (above) of the 'best cloth' says to me 'microfiber', which is 'synthetic, tightly woven, and smooth', But it is also VERY flexible... maybe too flexible, eh? The spray paint 'seals' AND stiffens it... How much in not enough, just right, and too much?... how do you judge...
What do you think of using silk?...
This is already overlong, but two more things. Back in the late 80's I had a couple of good quality JBL cabinet speakers which had the woofer surrounds deteriorated... I did not feel qualified to do the job myself, so I paid a local high end audio shop to do the repair... They never did sound right after that, sounded like they were 'stiff' or 'sticking'... I concluded, then, that the surrounds were too 'stiff'... Now, with what i have learned since, I think it is likely that they replaced the surrounds, but didnt remove the 'dome' to insure that the coil was moving freely...
I have a pair of Altec-Lansing 411-8A LF 15 Subwoofers which i bought from a friend a number of years ago, with blown ( 'gone' ) surrounds... look up the specs... recent offerings for these speakers on Ebay, with blown surrounds are at about $450 each... I only need one subwoofer for my home, i dont even want one in my car... So i fix both, keep one and sell one...
I dont wanna use a 'generic' kit for a 15 inch speaker for these babes... so I sent an email to A-L asking to get surrounds. they promise an answer in three days...
regards...
Dnorm
i read Memergencydpt.com instructable, its like the pro way to do it,
but yours it the most cheapest pro way to do it, wich is great. Some speakers have a plastic cone, will it glue to it as good as the paper ones??
