My problem was a little different than either of theirs. I had repaired the connector in the past -- the cord frayed and shorted right near the DC connector (the part that goes into the computer) so I spliced it and tried making a better strain relief. That lasted for a couple years but it broke again so I figured I'd try and replace the connector entirely.
Remove these ads by
Signing UpStep 1Disassemble the Old Connector
I used hot-glue as a strain relief in my last repair so I used a heat gun to get the glue off. I don't remember how the connector came apart originally, but the gist was to cut off the plastic shell then pry apart the metal shell. These are the pieces I came up with.
If you call the 3 segments of the new plug A, B, and C starting at the tip, you connect the ground ti the B section, and the +24 to the C section.
It was easiest for me to solder two wires to the B and C contacts on the plug, and then connect those new 2" wires to the +24V center and to the ground shielding. A little heat shrink tubing and electrical tape finished the job.
Not pretty, but it works and only cost $2.99 for the connector plug.
