Just a quick disclaimer: I am not responsible for any damage you do to your device or warranty. There are plenty of little fiddly bits inside one of these things that can be easily damaged through carelessness or accident. Also, I'm pretty sure if you open one of these yourself you invalidate the warranty. You have been warned.
***UPDATE 8/4/09:
I forgot to mention, you should probably try PhilB's instructable on the crazy digitizer problem first--you may not need a new digitizer at all! It didn't work for me, but after I'd installed the new touch screen, the DigiFix program was better at calibrating the new screen than the basic software.
***UPDATE 5/4/10: If you've repaired your Palm using my instructable, go into the Notepad and write, "Thanks depotdevoid!" or something along those lines. Take a picture of it and post it to the comments below, and I'll send you a DIY patch!***
Remove these ads by
Signing UpStep 1Get a replacement digitzer
The digitizer actually came in a kit that included a couple of screwdrivers and plastic prybars. I didn't need the screwdrivers, but the prybars certainly came in handy.
Other than that, it was painless. Thanks much for posting this information and the great photos!
This instructable was helpful for my m500-series Palms. Both look good and work great!
After replacing, on both units I had trouble getting the Palm touchscreen program to calibrate exactly. I also have Digifix and a trial version of PowerDigi. The Digifix did not seem to calibrate it accurately either, so I tried the PowerDigi. This one worked a lot better. I have 4 days left on my trial version. When it expires I am going to try the calibration again with both the Palm program and the Digifix. If either one of these do not work I will purchase the PowerDigi.
If you do learn anything about what causes this or how to fix it, please let me know and I'll add it to the instructable so anyone who comes here in the future is aware of it.
Either way, contact with the LCD shouldn't matter, as the flexible top layer of the digitizer is designed to make contact with the bottom layer, closing the gap between them and activating it. If it's not an issue with your software, that leaves only three options I can think of:
- A problem with the Palm's other hardware
- Damaged/defective digitizer
- Faulty installation
If it's #1, there's probably nothing you can do about it. I doubt it's #3 as you've gone back over everything. If it's #2, you'll have to get a new one and try again.None of these sound good. Go back over all the connections one more time. If that doesn't work, you'll basically have to make a decision whether you want to spend more money on a maybe by buying another digitizer. Unless you can convince whoever sold you the original one that it was defective (which is actually my guess as to the problem).
Good luck and keep me posted!
It's probably #2 as basically there is an issue with sensitivity, ie fingers are detected but not the find stylus point.
Something new: If I open notepad, I can draw with the stylus on the right side only, BUT if I use my finger I can draw anywhere on the screen, just not very precisely..
Only one comment: if you installed a glass digitizer your OEM stylus may now feel sticky or drag. I installed a high quality screen protector and it now works perfectly.
My TX is better than new. Thanks again.
Thanks for commenting!
Thanks again for your clear instructions.
Either way, I'd recommend just going back through, disconnecting everything, reconnecting everything, and see if that does it. Sometimes these things just have some little connection that needs to be jogged back into place.
If THAT doesn't work, it might just be time to cut your losses and call it a brick. You may have accidentally damaged the new digitizer during installation. These things are very fragile. However, it may be that there is something more deeply wrong with the palm, something beyond my sphere of knowledge. The only way to find out for sure (that I can think of) would be to get another digitizer and see if that fixes the problem. Personally, I wouldn't blow another $20 on a maybe.
Thank you for the kind comment Jim, and I'm sorry this didn't work out for you. Hopefully you'll be able to find the problem eventually!
Dead like it won't turn on. I assume that if it was the digitizer, it would turn on but I wouldn't be able to do anything from the screen. I therefore conclude that it is one or both of the flat connectors. I have carefully removed and reconnected a number of times with no sign of life.
Do you know of anything else that it could be? (other than the connectors).
Even though I was careful, it could have been zapped with static electricity.
Thanks for your help.
The whole static electricity thing is very possible. I open a lot of little electronic devices, and every now and then one will stop working for no apparent reason. I usually chock that up to static.
Sorry I can't be more help! Best of luck with your palm.
I just had a trouble with Step 4, for getting out the connector... until I "rotate" the black handle around its axis to be able extracting the wire connector...
I also had some troubles because my native language is spanish...and there`re some technical words that I didn`t know...
Thanks...
