3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Replace the Touch Screen (Digitizer) on a Palm TX
Step 8Final thoughts (updated 3/1/10)
I hope someone out there finds this instructable useful! I'm not sure how analogous this is to other brands/models, but I know that most touch screen technology is basically the same, so it shouldn't be a far stretch to do the same thing for your device.
Thank you for reading! Please take a moment to interact, as I greatly appreciate any comments, questions, ratings, or subscriptions you'd like to take the time for!
****UPDATE 8/3/09:
According to user PhilB, while he hasn't actually replaced a digitizer before, he has opened both a Handspring Visor and a Sony Clie. From what he's seen of my pictures, the insides look very similar, so replacing the digitizer on one of these units should be pretty similar to replacing it on the Palm TX.
***UPDATE 8/4/09:
I forgot to mention, you should probably try PhilB's instructable on the crazy digitizer problem first--you may not need a new digitizer at all! It didn't work for me, but after I'd installed the new touch screen, the DigiFix program was better at calibrating the new screen than the basic software.
****UPDATE 3/1/10
User stefpalmtx has noted that sometimes attempts to calibrate the screen when it's all buggy will screw up the calibration after you've replaced it with a new screen.  If you install the new screen and it doesn't recognize any taps, don't despair!  Try a hard reset first, that might just do the trick.
***UPDATE 5/4/10:  If you've repaired your Palm using my instructable, go into the Notepad and write, "Thanks depotdevoid!" or something along those lines.  Take a picture of it and post it to the comments below, and I'll send you a DIY patch!***
****UPDATE 1/1/11
User JOHNDWARD1 says that the DigiFix software didn't work for him, but a piece of software called PowerDigi did.  This is pay to use software, but it does have a free trial you can use to see if it will work for you!
10 comments
May 10, 2012. 4:06 PMcliveoboe says:
Thanx for a great instructable. My TX is humming like new except for the power button which has been long since dead. Luckily using one of the shortcut buttons to start Hotsync will turn the unit on. Used very small screwdriver to get case apart.
Aug 17, 2011. 9:18 PMbenstone says:
thank you! great walk-through. a small note you may want to add in step 5: my device came with conductive tape all around the digitizer to lcd edges. no problem cutting it with the pry tool.
Mar 27, 2011. 6:44 PMcvsoft says:
This instructable was helpful for my m500-series Palms. Both look good and work great!
Mar 28, 2011. 5:56 PMcvsoft says:
Thanks for the patch!
Jul 23, 2010. 11:01 AMsiemensj says:
I really appreciate the instructable. My Palm Tx works great now!
Sep 16, 2010. 5:13 AMpalmuser says:
Thank you for a detailed and very helpful guide. I just replaced my digitizer but have a problem. The left side of the screen does not react to the stylus, so horizontal lines drawn in note pad only fill up the right hand side.. However, I can sometimes press buttons and activate objects on the left side using my finger. There seems to be a problem of resolution (ie the fine stylus point fails but a think finger works..) I tried disassembling again, removing all the connectors but leaving the digitizer in place. I noticed on install that the connecting flat cable was a little longer than the original and, so some pressure has to be applied to close the case. Otherwise, the install was as per you’re the description. Can suggest something to try? Many thanks!
Dec 28, 2010. 5:45 AMJOHNDWARD1 says:
I had trouble with my calibration after replacing both my wife's and mine. I tried the Palm program, and on mine could not even get it to go to the next screen. It kept going back to the calibration screen. I also have Digifix and PowerDigi. Digifix did not work well either, on mine or my wife's. I then tried the PowerDigi. It worked very well. It has three different levels of calibration, with the higest being "Accurate" with 70 touch points of the screen. This program is not free, but you can try a trial version for free for 15 days. Try that and if it works you can purchase it for about $15. I have four days left on mine, then I will try the Palm and the DigiFix on more time. If these do not work, I will purchase PowerDigi.
Sep 16, 2010. 9:33 AMpalmuser says:
My problem seems different as when I rotate the screen, the dead zone remains the same. What I have noticed is that the active zone is actually the upper right quarter when the palm is vertical with the joystick at the base. Any ideas how the digitizer works? My guess is that its capacitive but i have read on google that some people speak of contact with the LCD.
Sep 17, 2010. 8:38 AMpalmuser says:
Hi, I dissembled once more but no cigar.
It's probably #2 as basically there is an issue with sensitivity, ie fingers are detected but not the find stylus point.
Something new: If I open notepad, I can draw with the stylus on the right side only, BUT if I use my finger I can draw anywhere on the screen, just not very precisely..
Dec 29, 2010. 3:14 AMpalmuser says:
finally got a replacement digitizer but the problem is the same. I guess there is a HW problem.. well, I knew one day my TX would die, its just a pity everything else works fine..
Nov 9, 2010. 6:16 PMbainvillewendy says:
I just replaced my digitizer for the first time ever. Very scary, but works perfectly. Good notes and good pictures. Thanks.
Sep 17, 2010. 5:31 PMchumpy1 says:
FANTASTIC !!! Easy to follow step-by-step instructions worked flawlessly. Great pictures make the job even easier. My Palm Tungsten TX works better than it ever has. I Highly recommend doing it yourself. It only took 10 minutes and I even applied a new Fellows WriteRIGHT to protect my new touchscreen investment even longer. THANKS…
Feb 23, 2010. 12:36 PMstefpalmtx says:
Warning, I had recalibrated before the replacement, and my digitizer was really broken.
I found out that a hard reset was obligatory so that I can perform the calibration anew (before the hard reset, taps were not reconized at all)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
306
Author:depotdevoid(depotdevoid on Facebook!)
Like me on Facebook, my poor, fragile ego needs a boost! I post updates about my current projects, and the occasional sneak peak at upcoming instructables! ...
more »
