Replacement Honda Hood Release Latch
Introduction: Replacement Honda Hood Release Latch
Instructions on installing a replacement hood latch for Honda CIVIC, Honda CR-V, Honda Element, and Honda Ridgeline. This part (PERMA FIX 900) was purchased on eBay.
Step 1: Remove Corner Kick Plate.
The first step is to remove the corner plastic kick plate from under the drivers side of the dash. This can be popped off with a flat screwdriver. It should be noted that some models of Honda CIVIC's and Honda CR-V's have 2 plastic push pins holding this corner kick plate on. These have to be popped off from behind with a long screwdriver, as the corner kick plate is being pried off.
Step 2: Trim Plastic Covering on End of Cable.
Now it is necessary to trim off about 1" of the plastic that is molded to the outer end of the cable. This can be done by nibbling at the plastic with a pair of cutting pliers. A small amount of heat from a lighter will help to soften the plastic. However this can cause a fire hazard and is not absolutely necessary. With a little patience and a sharp pair of wire cutters, the plastic can be trimmed off in 3 or 4 minutes.
Step 3: Install the Replacement Hood Latch.
Slip the new aluminum hood latch onto the end of the exposed cable. The replacement latch comes with the set screws and the Allen key. Tighten the 2 set screws.
Step 4: Replace the Corner Kick Plate.
Replace the corner kick plate and the job is finished.
    • Paper Contest 2018
      Paper Contest 2018
    • Science of Cooking
      Science of Cooking
    • Pro Tips Challenge
      Pro Tips Challenge
