Replacement Laptop Cord
I absentmindedly left the cord for my laptop power supply somewhere the last time I used the computer away from home. I was chatting with friends as I was packing up and forgot it. The business said no one turned it in as a found item.
I could order a new one and it would cost me about $20 (US) by the time it is delivered. I decided to make my own from this appliance replacement cord I found at Home Depot for $6.33 (US).
Step 1What size are the power supply pins?
Drill bits make handy sizing samples. By sight guess which drill bit is closest to each pin. All three pins were a different size on my power supply: 3/32, 764, and 1/8 inch.
68 comments
1-40 of 68next »
Jan 12, 2011. 6:23 PMmuyguapo says:
Why not use Sugru instead of hot glue to form the connection?
Jan 12, 2011. 8:13 PMmuyguapo says:
Online is the only place I know to buy it.
Jul 27, 2009. 10:13 AMfourletterfame says:
The patent websites I looked at for glue sticks indicated a low end melting temperature of 194F and a high end of 248F (90C and 120C respectively). If your power supply is in the heat range of boiling macaroni, you have deeper technical problems.
Apr 6, 2009. 5:23 PMBjorno says:
A good idea, but it is a risky endeavor for a small savings. Most retail electronics shops sell the "Mickey Mouse" style cables for ~%5.
Apr 7, 2009. 10:24 AMBjorno says:
Neither do I. The only part I worry about is the fact that you used hot glue to assemble the plug. Adapters like that can generate a decent amount of heat, enough to soften the glue and potentially short out. Though it is a slim chance, considering the prongs will hole the wires in place, it is still a worry of mine. Plastic epoxy is generally what I use to fashion that type of thing. Heat does not affect it and it is quite solid. I was a little off on the price, it is still around that $12 mark at most places.
Apr 20, 2009. 4:39 PMBjorno says:
Your power supply does not get more than lukewarm.
But you are posting this as an instructable for other people who's power supplies might very well get hot.
Keep in mind that I am not trying to knock you down, or insult your idea; only to add to the design.
Two heads are better than one.
Apr 21, 2009. 10:55 AMBjorno says:
But how are they going to do that if they are trying to use your instructable to build a cable in the first place?
Er, ~ $5, I should say.
Apr 15, 2009. 10:19 PMCaptmeach7 says:
I bought one of these at the local radioshack for 9.99, But this is essentially the same thing. copper wire wrapped in plastic. I dont know the difference between the heat the regular coating and the hot glue can take, but so long as it doesnt melt should be fine.
Apr 11, 2009. 1:25 PMzzzdude says:
Now tell me how to fix the other part of the cable, assuming the power supply box is in tact. I really don't want to pay 80 dollars for a replacement...
Apr 13, 2009. 11:49 PMzzzdude says:
Why thank you. You said exactly what I wanted to hear.
Apr 7, 2009. 8:57 PMhiheenah says:
Go to a hotel and tell them you stayed there a couple weeks ago and you forgot your laptop power supply in the room. Tell them you can't remember which room you stayed in. They will most likely bring a tub of left behind power supplies out for you to peruse. cost: Free. I work at a hotel. We have at least 50 of these things laying around.
Apr 8, 2009. 11:35 AMhiheenah says:
even better. If I was at the front desk, I would let you rummage.
Apr 8, 2009. 1:46 AMranm says:
Never forget that your insurance company probably will not pay for any damages caused by any eventual fire caused by this cord. Im not saying that the hot glue won't melt, but you can never be sure. Think about it. Even the real deal electronics you have might break down, even though they are following safety regulations! But in an emergency situation, this solutions seems to be pretty good (Y)
Apr 8, 2009. 12:21 AMcameron20020 says:
give the guy a break people! he has some good ideas
Apr 7, 2009. 6:20 PMJustDepends says:
lol i thought this was the entire ac adapter and stuff to.
that would have been helpful
Apr 7, 2009. 9:27 AMrimar2000 says:
Very good work, Phil. I did something similar, with the exception of the ground cable, for my notebook (my plugs were made of bronze sheet instead of copper cable). Not for lack of the original cord, but because this is so thick that it was not fit in the portfolio. But shortly after, I discovered that replacement cords are sold very cheap with the same plug. Maybe if you had asked or searched at Home Depot, you would have saved the job (and could not have done this Instruction)
Apr 7, 2009. 9:03 AMbfarm says:
A few dollars for a real - safe - UL Listed - replaceable line cord would be money well spent. Hot melt glue is not a legal insulator, does it breakdown after a while? Where is the strain relief? Also, the wrapped coils will loosen up after a while and start arcing which should assist in re-melting the glue. Really bad idea.
Apr 6, 2009. 10:52 PMins1jlm says:
you can find the cord you need at goodwill for 2 or 3 bucks
Apr 7, 2009. 12:56 AMrobotguy4 says:
Couldn't you also use a pair of calipers to get rid of the guess work? Nice idea with the drill bits though.
Apr 7, 2009. 1:12 AMrobotguy4 says:
Very nice Instructable. I wish I had this before I dissembled an old, cheap rechargeable Rockwell drill from the '70s that I bought for $3 at a rummage sale (sans cord). All I had to do was plug it into the wall socket (the drill used wall voltage) and I would (possibly) be good to go.
1-40 of 68next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
407
Author:Phil B
I miss the days when magazines like Popular Mechanics had all sorts of DIY projects for making and repairing just about everything. I am enjoying posting things I have learned and done since I got my...
more »
