Replacement Pivoting Mitre Saw Base
3,197
84
Posted in WorkshopTools
Introduction: Replacement Pivoting Mitre Saw Base
In this Instructables I will show videos building a replacement mitre saw base. In the first video I make design and cut the base which includes positive stops. The second video I install a fence and the angle locking mechanism, and in the final video I make a zero clearance insert, scribe the angle increments, and make a dust deflection baffle.
Step 1: Design, CNC'd Parts and Positive Stops
In this part I make a pivoting base or stand to mount the head of a cheap Mitre Saw, with the usual positive stops.
  • 00:02 Introducing the build.
  • 01:14 Cutting a miniature maquette / prototype.
  • 02:03 Testing fit of pieces.
  • 02:35 Making the positive stop.
  • 04:42 The pieces in birch ply.
  • 05:22 Adding ball catch.
  • 06:27 Installing saw motor.
  • 07:29 Re-installing saw motor.
  • 08:09 Fence positioning
  • 08:50 A natural end.
Step 2: Fence and Angle Locking Mechanism
  • 00:19 Planing the location of the fence.
  • 00:32 Screwing the base to the turning collar.
  • 01:10 Cutting fence pieces.
  • 01:30 Double checking line.
  • 01:57 Gluing fence pieces together.
  • 02:33 Drilling and screwing fence to base.
  • 04:48 Fitting rubber feat to base.
  • 04:55 Making locking handle.
  • 07:22 It worked.
Step 3: Zero Clearance Insert, Dust Flange and Increments
I don't talk much in this one, so these time codes might be more important.
  • 00:05 It's a bit stiff, I should sort that out later.
  • 00:26 Checking how accurate my angles are. Seems good enough.
  • 01:11 I use this flush trim bit to router a channel around the edge of the base, so dust can fall.
  • 02:08 CNC'ing the female part of the zero clearance insert.
  • 03:11 CNC'ing the male part of the insert plate.
  • 04:42 This insert is a little shallow, but that is not a problem.
  • 06:26 Extraction and making the dust baffle.
  • 07:40 I missed a stage - mere mortal.
  • 08:40 Cutting the rubber flange.
  • 09:27 TEST CUT
  • 09:44 Increments
  • 10:18 Using a razor to smooth the paint job - which I done off screen.
  • 11:33 Final Thoughts.
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Spotless Contest
      Spotless Contest
