Now that we have the lever removed from the bike, we are going to clean the areas where the new lever is going to come in contact with other metal parts. We are also going to grease the non threaded areas of the pivot bolt to insure smooth operation of the brake lever. After greasing the brake lever and pivot bolt, we are going to install the new brake lever. Slide the pivot bolt into the housing and brake lever. Screw nut back on pivot bolt and tighten with 10mm socket and flat head screw driver. That's it we are done with the brake lever. Make sure you adjust the pull to your liking using the adjuster knob on the lever.
