Please understand the risks of working on a car. If you hurt or car, yourself, your pets, your children, or your property, i can take no responsibility as I am not there to school you on proper car maintenance.
This instructable is on how to replace the lower ball joints on a '94 Chevy 1500. Some of the small details will be omitted like: How to jack up a vehicle, or Remove the tire… If you don’t possess these simple skills, this job may not be for you. It’s not uncommon to get some cuts and bruises while working on a car. However, some components like coil springs, Macpherson struts, and a falling car can kill you! Be safe and do your best to use the right tool for the job!
Remove these ads by
Signing UpStep 1Some tools required
The tools shown below are all you should need...if you don’t run into any problems. Inevitably, you will run into a problem, or you might like to use other tools to get the job done faster. In addition to what you see here, I also had to use a 24” Breaker bar, a propane torch (good for stubborn Nuts/bolts) and a ratchet set to speed things along.
I learned a trick for removing ball joints, tie rod ends etc... I know it sounds brutal but if you loosen the nut that holds the taper in place, take a sizable hammer (large ball peen or hand sledge) and wack the outside of the female taper (it usually takes 2-4 wacks), that taper will pop loose and you will not damage the boot with the pickle fork.
Of course if you are replacing the joint it does not matter, but if you will be reinstalling the old one it is important. This is quite the time saver and I heartely reccomend it.
Mikey
I have used the hammering method before, if your in a pinch yes it will work, but it doesn’t work all the time! Really old cars, big trucks, or rust and you will be beating on the ball joint all day and do nothing but putting dings all over the control arm. The press is only $40 USD and you can use it for breaks and universal joints as well, to me its money well spent.
The first time I did the ball joints on this truck years ago, I easily hammered one side out and when the other just wouldn’t hammer out… I got a press as a loner tool from autozone ($120.00 deposit).
I've been teaching auto shop for 10 years now and have pressed out too many to remember. I learnd the hammer trick not too long ago and have been overjoyed. I've a 1 ton chevy that I will be replacing the front end suspension on and am now looking foward to trying it.
Different strokes.
Have a safe one!
Mikey
I just wanted to add that in Canada at least many parts stores will lend out specialty tools like ball-joint presses for free.
That seems like it could easily mess up the taper of the steering knuckle.
Ah yes, I had a 73’ Nova I did the ball joints on years ago, at the end I had used a 3’ 10lbs (0.9144m 4.5 kg) sledgehammer and ended up with a smaller lumpier version of what used to be ball joints.
L
