They work well when new, but eventually fail and need to be replaced. Here's how to replace a GFCI outlet- or any outlet, really- or replace a standard outlet with a GFCI outlet.
Remove these ads by
Signing UpStep 1What you'll need
- New GFCI outlet
- Insulated screwdriver
- Outlet tester
- Non-contact tester
- Electrician's pliers
All are inexpensive. The non-contact tester is used to see if a circuit is "hot"- that is, if there's voltage on it. The Outlet tester is used to make sure you've wired everything properly.
But the new washer I just purchased has a three-pronged electrical cord...I am using an adapter right now, and the warnings on the washer say that's wrong. SO, I'm thinking I *still* need to install a GFCI to plug the washing machine into...but will the machine work with it? HELP! :^) And Thank You!!
You can't change the plug; it's required to be a 4-wire. However, since you say it's a new washer, it's almost certainly possible to change the cord (you should have asked for 4-prong when you ordered it :-). It's pretty simple to do, but not knowing which make/model washer you have, I can't offer details. You'll want to go back to where you bought the washer, or to a well-stocked hardware store, and ask for a 4-wire cord kit for your washer.
