Replacing an Upper Radiator Hose (Hyundai Trajet)
Published
Introduction: Replacing an Upper Radiator Hose (Hyundai Trajet)
About: As of April 2017 I have decided to no longer post on instructables. The fact that several of my published works have been removed without my consent is inexcusable. Also the insult of an author having no co...
The OEM factory installed hoses in the 2000 Trajet are stiff, crackly and they will fail! Time to do proactive replacement!
Step 1: Removing the Old Hose.
Due to age and heat, the old rubber hose was firmly bonded onto the engine and radiator nipples. Using a a firm grip on the hose, the ends were removed.
See the sediment lining the inside of the hose? Not a good sign.
Step 2: Comparing Oem and Aftermarket.
The oem is form molded for the car but the aftermarket is flexible enough to work well.
Step 3: Installing the New Hose.
Installation was quite easy. I used SS hose clamps to secure the ends onto the nipples.
A full gallon of Coolant was needed to fill back the cooling system.
Now the engine has a new radiator hose. Next job is to find the lower hose and replace it!
  • Casting Contest
    Casting Contest
  • Woodworking Contest
    Woodworking Contest
  • Make it Move Contest
