3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Replacing an XBOX DVD drive
Step 5Close the case
Close the case
Reattach all 6 screws in the case and the rubber feet and you're done!
3 comments
Jan 26, 2009. 6:18 AMfitzovia says:
I want to replace my xbox lens with a normal dvd lens to see if it will work. But before I do that I want to know if someone has done it before and the risk.
Mar 31, 2010. 4:32 PMdaiatlus79 says:
well..the issue would be the sheer harward compatiblity,.. you CAN get away with a PC dvd drive in an xbox.. but now replacing with a regular dvd lens inside the stock xbox drive may be rollnig the dice... i would look for a hardware compatibilty list.. you can buy replacement lasers for dirt cheap on amazon..
Feb 7, 2009. 6:44 AMandrewl10 says:
If you did replace it and it didn't work, it shouldn't hurt your xbox. I wouldn't worry about that aspect. The only real problem is the power source for it, because an xbox uses a different type of power cord for their DVD drives than normal computer ones do. You could build your own if you wanted to though!
Feb 11, 2009. 6:22 AMgimili2 says:
Could I buy any normal DVD-ROM IDE Drive and get it to work?
Jul 21, 2009. 6:53 PMdaiatlus79 says:
if it is soft or hard modded and the bios is altered.. but it is only certain drives (i believe some Samsung and LG brand ones can)
Apr 8, 2009. 12:45 PMdrumagon says:
That doesn't really look difficult at all. What is the cost for the xbox specific drive? I was looking at buying a functioning console to play around with, but some people practically give away broken ones. When an original xbox console goes bad, how often is it the disc drive? What else can go wrong, and how often?
Jul 21, 2009. 6:50 PMdaiatlus79 says:
depends on brand and avaliablility. sometimes it is cheaper to just get a new laser and replace that as it is easier to get the replacement laser, than the whole drive. and if it is the Thompson brand drive it can be the usual problem (Thompson dvd drives are notorious for failing).
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:sMoRTy71
