Replacing the Distributor Without Using a Timing Light (Honda Civic 1999 D15B)
1,531
5
Posted
Introduction: Replacing the Distributor Without Using a Timing Light (Honda Civic 1999 D15B)
Continuing with my preventative maintenance program on my car, the 16 year old distributor in the engine will be changed out to a new unit in this instructable.
As per the Honda service manual, I began with the removal of the OEM distributor.
This instructable is about a distributor replacement without having to use a timing light to get the ignition timing as with the oem distributor.
Step 1: Removing the OEM Distributor.
I put a line on two of the distributor mounting flanges and then I took off the spark plug wires. Luckily the pics I took will guide me to put the wires back into place for the new one.
I removed the connector by prying the holding clip on the metal bracket.
Using the metal bracket I took measurements on the top and left bolt washers. The top bolt washer is 5mm from the flange edge. The left one is 7mm. Again I used the metal bracket on the distributor to steady my measuring tape.
Three bolts to remove and the distributor pulled out of the engine camshaft easily.
Step 2: Comparing the Old and New.
They look more or less identical. I'm happy that new distributors are still on sale via Amazon.
Before installing the new distributor I made sure to turn the shaft to line up as with the oem. See the last pic for that.
Step 3: Installing the New Distributor.
I used a rag to clean the area around the camshaft. I put some oil on the o rings and slotted the new distributor in place. Using the measuring tape I made sure to get the bolts and flange edges identical to the oem position.
Step 4: Completion and Testing.
The electrical connector needs to be mated first with both halves then slid into the metal support bracket. After putting back the spark plug wires, I cranked her up and she works perfectly!
No need to spend money on a one use timing light! I hope this instructable has been helpful to fellow civic folks.
  • Metal Contest 2017
    Metal Contest 2017
  • Wheels Contest 2017
    Wheels Contest 2017
  • Remote Control Contest 2017
Questions & Answers
2 Comments
