3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Replacing the Pickups in Your Guitar
If you're anything like me, you started out with a basic beginner's guitar, and over time you realized that you were ready for something better. I had a Squier Telecaster(standard series) and I was ready for a change. I was set on a Les Paul of some sort, possibly a used LP Standard. I read tons of reviews, then I started reading some of the Epi Les Pauls(the nicer ones, $400-500).
Long story short, I realized that I wasn't going to be able to afford even the cheaper Epi guitar of my choice, and even if I could save up the money, it would have to go towards getting a vehicle, when I turn 16 in 7 months.
After some time on Google reading articles mentioning the good things that can come out of getting rid of the stock pickups on inexpensive guitars, I was set on trying to do this myself. I had never considered it before, I always thought that the insides of guitars were something only an elite group of individuals were allowed to mess with.
I was wrong. After finishing this pickup swap, I learned a ton about my guitar without messing ANYTHING up. And now I have a great sounding guitar, too.
If you're finally becoming good at guitar, or even if you have been playing for a while and want a change, swapping out the pickups is one of the best things you can do without shelling out hundreds for a new guitar.
Disclaimer-
I think that following this tutorial is pretty simple. You should be able to swap out your pickups with minimum to no hassle, but in case you screw up, don't blame me for it. If you do mess something up, I'll do my best to help you though.
Also, this tutorial is geared towards changing the bridge pickup to a SD Little '59 on a Telecaster, but the same technique should be able to be applied to other guitars as well.
Step 1Choosing a Pickup
Choosing a Pickup
Choosing a pickup is important. Why?
-They're not cheap. Expect to spend $70-130(USD) on a good pickup.
-It'll change the way your guitar sounds. Look for video reviews with good quality audio to help determine what you need. Seymour Duncan also provides audio samples for their pickups. http://www.seymourduncan.com/support/audio-samples/tele_jaguar_and/
Make sure you like the sound before you buy it. Don't go off of text reviews alone(although you should read those too). Everyone's opinion is different.
I chose the Little '59 because I wanted a humbucker(vague, I know...), and there were good reviews on it. Also, I was pleased with the way it sounds.
I recommend you buy your pickup new, and from a place that you trust. I am getting more and more unsatisfied with Musician's Friend(everything I order is backordered...) so after being informed that my pickup was going to be in stock three weeks from when I wanted it, I canceled the order, bought the same pickup at Guitar Center(online) and it came in by the end of the week.
Also, make sure you know where the pickup is supposed to go(not just what type of guitar it is supposed to go in). Don't screw up and buy a neck pickup and try to put it in the bridge.
That is, of course, if your guitar doesn't have interchangeable pickups. Like a Tele.
37 comments
Feb 9, 2012. 6:09 PMfreeza36 says:
nice guitar man
Sep 29, 2011. 9:46 AMmrmerino says:
Ha ha. I draw pots the same way.
Oct 25, 2010. 1:26 PMFoiL says:
Stuff everything with cotton. Usually it keeps any buzzing from happening.
Aug 15, 2010. 10:24 AMKrytenthesmug says:
Klooa is right. I had the same problem with a S-D pickup, went back to rubber tubing (cut from a length of fuel hose from a model plane), but no difference. I wax potted mine and the microphonics went straight away.
Jun 22, 2009. 12:06 PMbustedit says:
Nice ible. I JUST got a Squier Tele Custom ii (2) in the mail Friday after selling a keytar on ebay for $355. I bought it because it got great reviews for having 2 Duncan (designed, made in asia?) P90's and the price was right for a 1st guitar. the only thing i do not like is the ugly tele headstock. I bought a '68 Harmony Marquis last year for my 1st 1st guitar, not really knowing at the time how unrewarding/difficult it would be to learn on a P.O.S like that. So, even tho the pups are probably the last thing I would replace on it, it was cool to read a bit by someone else with a "less expensive" tele. Look up the Custom ii online, it has a great looking pickguard and the pup selector is up on the top horn like a les paul. Thanks for the tips!
Sep 21, 2009. 4:12 PMdiy-guitar-guy says:
what cha got yourself there partner is an awsome guitar! if you dont like the headstock you should have got the exact same but with the strat headstock and their cheaper! or you could change the neck to a blank headstock and there is a guy on ebay that will print you out a vinal sticker for it or if you have the cash get a fender neck and let people think its a fender!
Sep 21, 2009. 3:47 PMdiy-guitar-guy says:
dude it looks in the first pic like you had to widen the hole for the pick up in the plate. did you? thanks this is great, if i had seen this before i would have defo done this to my crappy squire strat. but hey there nothing wrong with squires?! :) keep rocking my friend!
Sep 18, 2009. 6:11 PMklooa says:
It's not the springs. Either return the pickup, or Pot it in wax (Heat up some wax and dip it) This will stop the internal wires from vibrating, and kill the microphonics.
Jul 17, 2009. 2:01 PMSeMi_AuToMaTic says:
Hey man this is a really great instructable and i am in sort of the same situation that you were in. I have 2 guitars,a Yamaha CG-101 classical, and a Fender Squier Strat. I want to save up for a warlock or Eipiphone les paul or SG or something, but my income is very low and i am going to get a drum set instead. My parents could care less of music, but they are in it for me. Anyways, my strat has three single coils and what I really want to do is replace them all with EMG's.Would that be possible? But those are like $200 a peice. Maybe i should just wait until i get some more money after my drum set. Thanks and shoot me a PM or something.
Jul 3, 2009. 7:23 PMFarewell88s says:
I was thinking of doing this with my epiphone les paul Black Beauty(it has 3 humbuckers) and this instructable gave me more confidence in myself to actually try it!
Jun 14, 2009. 6:53 PMluvit says:
i once disassembled my yellow Ibanez guitar and sanded it down. i never reassembled it.
Jun 16, 2009. 4:16 PMluvit says:
i bought a les paul, like slash. ..i didn't like feeling like stryper.
Jun 14, 2009. 11:24 AMannrrr says:
Putting on two strings is of course the best way to get an understanding of the tone and such. But if you are being lazy you can also check you pickup is working by using a tuning fork ($2). You just bang it on something (not the guitar of course!) and let if vibrate over the pickup. If it is working, and you have it hooked up to the amp and all, it will make a noise. But it looks like you didn't have difficulty...just thought I would share this trick. Using a simple circuit (not involving the pots and such) I used this to check that some pickups (used) I got actually worked.
Jun 15, 2009. 7:53 AMInfamousKirch says:
If you do this and you're having issues with strange weak guitar tones, instead of what you expect out of your new humbucker pickup you probably got the positive and negative wrong, just switch the wiring the other way and you'll be golden... Nice instructable & It's always good to remind people that the neck needs oiled and fixed-up a bit every time the strings are off.
Jun 12, 2009. 11:47 PMabadfart says:
nice i want a telly
Jun 14, 2009. 8:36 PMabadfart says:
ya my buddy has a les paul (epi) and it is amazing i have a strat but i had a telly knock off but the body split
Jun 14, 2009. 6:34 AMgummypaul says:
Is the grounded wire on the switch what goes to the bridge ground?
Jun 14, 2009. 7:42 AMinteractive3 says:
What did you use to polish the frets? What did you use to oil the fretboard? I use the fine Scotchbright pads (gray) for polishing the frets and Lemon Oil for the fretboard. (Weiman Natural Lemon Oil Furniture Polish "cleans, moisturizes, & preserves" Contains no silicone)
Jun 13, 2009. 11:49 AMSchmidtn says:
Guitar Center has owned Musician's Friend since 2000... check out, "Guitar Center," on Wiki. That's why their prices are the same, so just order from whomever has what you need in stock.
Jun 13, 2009. 1:13 PMSchmidtn says:
Yup, same company and same prices. It's just a little trick to order from who has it in stock to save you the few weeks delivery time going from warehouse to warehouse.
Jun 12, 2009. 7:36 PMgmoon says:
Good guide-- I like what you've done here. Good pics, too. Of course, it's "Tele" specific, but a lot of the information can be adapted for other wiring schemes.
Jun 12, 2009. 2:40 PMmicroman171 says:
I'm going to do a good check up on my electrics. It is the best shit guitar I've played. $400 with amp deal... For some reason, it sounds better than any Ibanez I've played. Anyway, what do you think of shielding the cavity? I can get some copper foil sticky-backed sheet, and then connect that to ground. I'm definitely replacing my jack, but I think my pots will be okay. Everything is getting a damn good clean! Got any tips for polishing the paint? It has the odd small scratch. Either that or I could sand it to a matt job? Or would that look crap?
Jun 12, 2009. 5:15 PMmicroman171 says:
No pictures sorry :-P
It's a fender style black paint, white full pick guard.
I'll need to get some new strings =\. Polishing the frets should be cool, should look real nice after.
The paint have a few very minor paint scratches, I thought I might be able to improve the gloss a little. Is there an alternative to guitar polish? I saw something about car polish, figures... Similar paint jobs.
I have single coils, and would have to replace the pick guard to upgrade... Not too keen on shelling out for new gear. I'm actually in the process of hand crafting a scratch-built Gibson SG copy. MDF anyone? I hear MDF gives a nice low, continuous tone. Obviously it's going to have a good paint job to cover it up...
I've also crafted the neck from NZ native Rimu. Looks really nice! Was thinking of putting an ebony fretboard on, just to give it a nice, professional surface.
I'm an electrical hobbyist, so I know all about the various components, I just know little about audio. I guess I wont be shielding then, will save my wallet a bit =).
Thanks Mate, great instructable BTW. I'm going to use it for sure! Just without the pick-up part...
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
9
Author:John Smith
I'm15, I enjoy playing guitar, music, and metalworking. As far as music, I have over a thousand songs of the best music ever(classic rock!). I have a Squier Tele and an Alvarez acoustic. I have a Rola...
more »
