Step 6Unscrew Control Panel
When you take it off, be gentle and don't force it. If it doesn't want to come off it might be because you're pulling on a wire.
Lay it right next to the cavity so that you can see the wires clearly.
Find the pickup wires. If you are working on a single coil one like this, you should have two wires per pickup. Somewhere in there you should also have a ground for the bridge plate. Mine was a separate black wire that came through the same hole that the pickup wires did.
Add Comment
