Step 5Wireing it up
BEFORE YOU DO ANYTHING slide in the jack cover, any heatshrink and other stuff you want on the wire.
The big one is ground - the other two are tight and left channels. I prefer passing the wires through the inside, then soldering the outside . Clamp the jack pointing away from you, with the Ground connecter below. The small pin to your right is right, the one to the left is left. Solder these in place.
On the other hand, i'm certain the headphone will sound better with a working jack, than a broken one ;)
By the way, my granfather helped me a bit with the soldering, and it works like the new :) I'm very happy adout it, so thanks again
I suppose you can splice, or replace (it dosen't really need to be headphone wire, any sufficiently thin wire will do)
for the jack connection, i totally reccomend getting the metallic sorta jack, and using heatshrink and hot glue for extra strength
You could possibly cut the old cable VERY close to the headphone, have some other wire just as reinforcement, and heatshrink, maybe.
if its not fused in place, there's also always a peg or 3 you can carefully dislodge to take it apart, or screws. If you have nothing to break cause its already broken, a little courage, a little patience, and a little work can always save the day
