Replacing Transmission Fluid.
Published
Introduction: Replacing Transmission Fluid.
About: Update 12 September 2017: A very special thanks to Sam Elder, a manager here at Instructables, who tracked down the cause of my lost publications and fixed the issue. Take a bow Sam!
In the hot climate of my tropical home island, it's a good practice to change transmission fluid annually. My preference is full synthetic fluid. It simply lasts long and I have been using various brands for the past 7 years.
Step 1: Removing the Fluid.
For my wife's car, the drain bolt is seized stuck. To remove the fluid I use the dip stick pipe.
Step 2: Suction Action!
I used a hand pump to remove the fluid into spare bottles. These I disposed of properly afterwards.
Step 3: New Fluid!
Using a funnel I put 4 quarts back into the transmission. I turned on the engine, let it warm till the radiator fan came on and put the gear in in all selections as per the manufacturer instructions. Finally I put the gear in neutral and checked the dip stick. Verifying the proper level on the dip stick the job is now done!
    • Woodworking Contest
      Woodworking Contest
    • Make it Move Contest
    • Oil Contest
      Oil Contest
