My cordless drill has been sitting on the shelf, useless, because the batteries are dead. Not anymore...I replaced the internal batteries with ones that were a higher quality and longer lasting! Others have suggested zapping NiCad batteries with high current...this may work, but also runs the risk of damaging any internal circuitry the battery may have, and could cause the batteries to explode and spray hot/toxic chemicals over you! It's also only a short term solution. This is a safer method with a guaranteed outcome, and a great upgrade. If you're on a very tight budget and have shorted NiCd cells, you can isolate the bad cells with a multimeter and just replace the bad individual cells.
SUPPLIES REQUIRED:
1) Soldering equipment
2) Small heat shrink tubing (optional, if your battery pack requires splicing)
3) Large heat shrink tubing (optional, if your battery pack has a temp sensor)
4) Correct screwdriver bits for disassembling the battery case
5) New replacement batteries (see step 2 for help)
In theory this can be done to just about any item that uses rechargeable batteries, but results may vary depending on many factors. Do not attempt this unless you are confident soldering and working with high power electrical circuitry - many of these batteries pack a mean punch, especially when assembled! NOTE: they carry enough current to weld in some cases. In this example I will be using the battery from a Craftsman Professional 9.6v Cordless Drill, item # 9614 or 11030.
NOTE: This was the first time I've used a very old camera and I did not realize that the pictures were not great until after the project was over...please let me know if you need more pictures or info!
Remove these ads by
Signing UpStep 1Is your battery pack a candidate?
1) How easy your battery pack is to open up
2) How ambitious you are in opening up your battery pack
I have seen three basic types of battery cases so far:
BASIC SCREWS:
The easiest are assembled with standard screws...nothing special there!
SPECIAL SCREWS:
To make things more difficult my battery pack used special security torx bits. A cheap security bit set at Ace Hardware contained the bits I needed. Here is the $3 bit set available online for $3.
NO SCREWS:
The hardest type would be a battery case that is not screwed but glued together (for example, my laptop battery...which I'm debating doing this to)...some of these were never designed to be disassembled and you may break it in the process! I suggest that you do not attempt to open one of these up unless you could see a way to get it apart cleanly, were desperate to upgrade, or about to throw it in the trash...basically you need to be willing to risk destroying the case. You may be able to re-assemble without any signs that you've taken it apart, or you may damage the case beyond repair...you'll have to be the judge.
It helped me fix a defective power drill battery pack - when I disassembled to change the batteries I noticed that a soldering point was broken. Fixed that and now works like new.
Thank you!
NiCd - Really ideal for power tools. They take a beating and keep on going, and they're cheap. If I used the drill more or for heavy duty use I'd have went with these, but I didn't want to loose another good battery pack to dendrite crystals. I was willing to give up a little 'ooomph' for longer runtimes.
NiMH - Not ideal for most power tools. Still, I made an educated decision and selected these because I wanted a lighter duty drill that will last longer with a full charge. With that said, your application may differ and if I used this drill more I would have went with NiCd. Probably the biggest thing to watch out for is your charger...compared to NiCd these batteries NEED a slow charge. I have a trickle charger so it wasn't an issue, but not all NiCd chargers will work! (Although I infrequently miss the extra punch in the NiCd's had, the NiMh's still get my small jobs done. For example, I sometimes think that it might get bogged down when doing something like drilling a 3/8" hole through a 2x4, but it manages to get through, just slower than it would with NiCd batteries).
LiIon -I would not use these as a power tool battery. The deal-breaker is that they're just not safe in a high-discharge and/or rugged environment. Great for low voltage and long term items...like a watch battery. With that said, there are exceptions (ie, LiFePO4) which are more ideal for power tools, but for the price they just don't hold much juice. I'm not sure offhand how much of a punch they pack but my hunch is that they're less than NiMh...though you'd want to look it up to be sure.
Having said all that, I'm sure that most power tools are built/designed with a certain battery type in mind. It's an "experiment at your own risk" situation unless you are fairly certain about the details. As always, Google can tell you more than you ever dreamed possible (it's the ultimate rabbit hole).
This is an adequate step-by-step for using the "with Tabs" cells the writer referred to. If you just have the cells sans tabs, here are a couple tips:
1. Use the lowest possible setting for your soldering iron...just barely melt the solder and use FLUX!
2. Try using non-braided wire (around 16ga) instead of tabs to connect each cell to one another.
3. Use a rotary tool to lightly scuff the surface of the cells and also the surface of your connecting material.
4. Don't mix old cells with new cells; your battery is only as good as its weakest cell!
Source: Built and repaired batteries(especially drill packs) for over 4 years for major retail company.
