Replicating "Old-School" Texting With an Arduino, a 4x4 Numerical Keypad, and a 16x2 LCD
9,467
26
15
Posted
Introduction: Replicating "Old-School" Texting With an Arduino, a 4x4 Numerical Keypad, and a 16x2 LCD
Hello! This is a tutorial to produce a text-composition device using an Arduino with text storage and return capabilities to the serial console. In its current form it is not particularly useful, and is more of an entertaining exercise, but the hardware setup and code may be expanded upon or incorporated into other projects as a relatively cheap way to compose text. With the addition of a GSM or 3G shield, and minor code changes and additions, this setup could actually be used as a simple text-sending phone.
Here is a video demo of most of the functionality, including text entry, line wrapping, screen-clearing, spaces, backspaces, serial output, and the end of composition menu, featuring the re-display of stored text upon backspacing, as well as the capability to output a final message and clear the display and storage.
You will need:
An Arduino (I used an Uno R3)
A 16x2 LCD (with or without backlight, your choice. Different sizes could be used with accommodations made in the code)
A breadboard, male-male and male-female jumpers (depends on how permanent this will be, and what headers are where)
5x 2k ohm resistors
1x 240 ohm resistor
The resistor values are not nessisarily set in stone, the 2k ones could most likely be subbed with anything 1k-5k, and the 240 could be anything 100-500, but I make no guarantees that those will cooperate (they probably will though). One of the 2k's and the 240 are used for creating a voltage divider for the contrast on the LCD. Normally this is accomplished with a potentiometer, so substitute as you feel fit.
Step 1: Hardware Setup
The diagram should explain the majority of the hardware setup, which is essentially an expansion of your typical basic LCD setup. Data output lines, however, are shared between the LCD and the keypad. These outputs go to the rows on the keypad in order to normally write them high. If any press occurs, it is detected by one of the columns going high, as the columns are hooked up to be inputs. A high signal as then cycled through the rows and then the keypress is located based on which column goes high when which row is high. Afterwards all rows are returned to the initial high state. After any commands to the LCD, all rows are written high again to ensure that no odd behavior occurs on the LCD, and keypress detection still functions. The resistors on the right of the diagram are the 2k ohm pulldowns for the column inputs to the Arduino, and the resistors on the left for the voltage divider that (as I mentioned earlier) can be replaced with a potentiometer if one wishes to do so.
Step 2: Code
I've attempted to comment this code extensively, but if anything in it remains unclear, please do ask! I've attached the .ino file to make uploading the code simple.
Note: I wrote this code before I had a handle on Object-Oriented Programming, and so the structure and organization of the code could certainly be better, but it still does function perfectly. I would update the code, but I no longer have the hardware on-hand and so would not be able to test it sufficiently. It is my hope, however, that the lack of OOP will make the code simpler to follow for Arduino beginners.
Step 3: Finished!
I hope that you found all this useful! If you have any questions feel free to ask. Thanks!
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Microcontroller Contest
    15 Comments
    hello, I use this code to my project sms text
    messaging with gsm900d and I add some
    code my project need to input the NUMBER
    & MESSAGE , when I input the
    number alone i can receive a message but
    when i input the number and message I can’t receive any message.. how can fix this please help me . here’s the code I add.
    #include
    <LiquidCrystal.h> //include the
    lcd library
    #include <String.h>
    #include <Keypad.h>
    #include
    <SoftwareSerial.h>
    #include
    "SIM900.h"
    #include "sms.h"
    SMSGSM sms;
    const byte row1=3; //keypad row pins, shared with the lcd
    data lines
    const byte row2=4;
    const byte row3=5;
    const byte row4=6;
    const byte col1=7; //keypad column lines
    const byte col2=8;
    const byte col3=9;
    const byte col4=10;
    LiquidCrystal lcd(12, 11,
    row4, row3, row2, row1); //lcd object
    byte numpressed; //latest
    number pressed on the keypad
    byte timespressed; //times
    the number has been pressed
    byte cursorx=0; //cursor x
    position
    byte cursory=0; //cursor y
    position
    byte lastnumpressed; //the
    initial number pressed on the keypad
    char letter; //stores
    letter that needs to be printed to the lcd
    char typedtext[140];
    //stores typed text for printout to the serial console
    char phoneNumber [12];
    const int wait=1000;
    //time to wait for additional presses to same number
    const int
    preventholddelay=150; //time to wait to prevent cycling through things too
    quickly
    unsigned long basetime;
    //base time for while loop
    unsigned long elapsed=0;
    //elapsed time in while loop
    bool
    disablespacedelay=false; //disables the delay in the space function in the case
    that a different number is pressed while in while loop
    bool promptkeypress=false;
    //used for waiting for, and keypress detection, at the end-of composition
    prompt
    const byte
    maxtimespressed[16]={
    1,3,4,4,4,4,4,4,4,4,1,7,1,1,1,1}; //stores
    maximum number of times any given key can be pressed before looping back to its
    first letter (used by incrementtimespressed function)
    int positionintypedtext=0;
    //position in typedtext character array
    int charremaining;
    //remaining characters in message
    int
    positioninphoneNumber=0;
    void setup(){
    //KEYPAD
    Serial.begin(9600); //initiate gizduino witha baud
    rate of 9600
    lcd.begin(20,4); //initialize the lcd
    lcd.setCursor(cursorx,cursory); //set the lcd
    cursor
    lcd.noCursor(); //turn off the cursor
    pinMode(row1,OUTPUT); //set the rows as
    outputs
    pinMode(row2,OUTPUT);
    pinMode(row3,OUTPUT);
    pinMode(row4,OUTPUT);
    pinMode(col1,INPUT); //set the columns as inputs
    pinMode(col2,INPUT);
    pinMode(col3,INPUT);
    pinMode(col4,INPUT);
    delay(wait);
    lcd.cursor(); //turn the cursor on again
    after a delay equivalent to wait
    rowshigh(); //sets all rows high
    mainMenu();
    void loop(){
    numpressed=16; //reset
    "numpressed" (16 doesn't refer to any button on the pad)
    if (findpress()){ //look for presses, if one
    has occurred, identify it and continue
    timespressed=0; //reset
    "timespressed"
    if (numpressed==0){ //if zero on the pad
    was pressed,
    dozero(); //print zero
    letter='0'; //manually seed a zero as the
    character for the text storage
    textstorage(1); //regular character
    storage
    if (numpressed==10){ //if shift on the pad
    was pressed,
    textstorage(2); //perform a space in
    storage
    dospace(); //do a space
    if (numpressed==14){ //if the arrows on the
    pad were pressed,
    textstorage(3); //perform a backspace in
    storage
    dobackspace(); //do a backspace
    if (numpressed==15){ //if enter on the pad
    was pressed,
    if (gsm.begin(9600)) //condition if gsm is initialized
    Serial.println("\nstatus=READY"); //displays "ready" on the serial
    monitor if gsm is ready
    else
    Serial.println("\nstatus=IDLE"); //otherwise displays
    "idle" on the serial monitor if gsm is not found
    delay(1000);
    sendTextMessage();
    lcd.setCursor(3,3);
    lcd.print("Sending..");
    lcd.clear();
    delay(1000);
    mainMenu();
    outputserial(); //output message and
    display remaining characters to serial console
    if
    ((numpressed<10&&numpressed>0)||numpressed==11){ //if
    1,2,3,4,5,6,7,8,9, or 11 was pressed (any one of the keys with multiple
    characters assigned),
    lastnumpressed=numpressed; //record which
    number was pressed,
    basetime=millis(); //and take a base time
    for the while loop
    while (elapsed<wait){ //while below
    the time to wait,
    if(findpress()){ //look for presses, if
    one has occurred, identify it and continue
    if (numpressed==lastnumpressed){ //if
    it was the same as before,
    incrementtimespressed();
    //increment "timespressed"
    basetime=basetime+(wait-(wait-elapsed)); //roll up the base time, to
    allow another wait period until next press of the same button
    definepress(); //use
    "numpressed" and "timespressed" to define
    "letter"
    lcd.print(letter); //print the
    letter that was defined
    //maintain cursor position
    rowshigh(); //return all rows high
    delay(preventholddelay); //delay a
    little to prevent continuous cycling through "timespressed" during a
    single press
    else{ //if the number that was pressed
    was different than before,
    disablespacedelay=true; //disable
    the delay in the space function to allow the press to be detected a second
    time, at the beginning of void loop
    break; //break out of the while
    loop
    elapsed=millis()-basetime; //refresh
    the elapsed time for the while loop
    elapsed=0; //reset the elapsed time for
    the while loop
    textstorage(1); //store character
    if (positionintypedtext==139){ //if the end
    of the stored text has been reached,
    promptkeypress=false; //reset keypress
    detection
    cursorx=0; //set cursor to the beginning of
    first row
    cursory=0;
    lcd.print("Msg end.
    <>=back"); //print this out to the lcd
    second row
    cursory=1;
    lcd.print("enter=serial out");
    while(!promptkeypress){ //while no relevant
    keypresses have occurred,
    "timespressed"
    the pad were pressed,
    promptkeypress=true; //take note so
    that the while loop can be broken
    in storage
    for (int i=0;i<16;i++){ //print
    out to the first line on the lcd from the stored text
    cursorx=i;
    cursory=0;
    lcd.print(typedtext[108+i]);
    for (int j=0;j<16;j++){ //print out to
    the second line on the lcd from the stored text
    cursorx=j;
    cursory=1;
    lcd.print(typedtext[123+j]);
    cursorx=15; //set cursor to the
    beginning of second row
    cursory=1;
    pad was pressed,
    Serial.print("Final message:
    "); //print this to the serial console
    Serial.println(typedtext); //print
    out all the text typed so far to the serial console
    Serial.println(); //print a blank line
    for (int i=0;i<140;i++){ //write
    all positions in the stored text to be blank
    typedtext[i]=' ';
    positionintypedtext=0; //reset the
    position in the stored text to the beginning
    doclear();
    delay(preventholddelay); //delay a little
    void rowshigh(){ //sets
    all rows high
    digitalWrite(row1,HIGH); //write all the rows
    high
    digitalWrite(row2,HIGH);
    digitalWrite(row3,HIGH);
    digitalWrite(row4,HIGH);
    bool findpress(){ //finds
    a press to define "numpressed", if any press occurs, returns true
    bool pressfound=false; //variable for any
    press detection, is returned by this function
    digitalWrite(row1,LOW); //write all rows low
    digitalWrite(row2,LOW);
    digitalWrite(row3,LOW);
    digitalWrite(row4,LOW);
    digitalWrite(row1,HIGH); //write first row
    high
    if (digitalRead(col1)==HIGH){ //if the first
    column is now high, "1" has been pressed
    numpressed = 1;
    pressfound=true;
    if (digitalRead(col2)==HIGH){ //if the second
    column is now high, "2" has been pressed
    numpressed = 2;
    pressfound=true;
    if (digitalRead(col3)==HIGH){ //if the third
    column is now high, "3" has been pressed
    numpressed = 3;
    pressfound=true;
    if (digitalRead(col4)==HIGH){ //if the fourth
    column is now high, "reset" has been pressed
    numpressed = 12;
    pressfound=true;
    digitalWrite(row1,LOW); //return first row
    low
    digitalWrite(row2,HIGH); //write second row
    high
    column is now high, "4" has been pressed
    numpressed = 4;
    pressfound=true;
    column is now high, "5" has been pressed
    numpressed = 5;
    pressfound=true;
    column is now high, "6" has been pressed
    numpressed = 6;
    pressfound=true;
    column is now high, "dial" has been pressed
    numpressed = 13;
    pressfound=true;
    digitalWrite(row2,LOW); //return second row
    low
    digitalWrite(row3,HIGH); //write third row
    high
    column is now high, "7" has been pressed
    numpressed = 7;
    pressfound=true;
    column is now high, "8" has been pressed
    numpressed = 8;
    pressfound=true;
    column is now high, "9" has been pressed
    numpressed = 9;
    pressfound=true;
    column is now high, the arrows have been pressed
    numpressed = 14;
    pressfound=true;
    digitalWrite(row3,LOW); //return third row
    low
    digitalWrite(row4,HIGH); //write fourth row
    high
    column is now high, "shift" has been pressed
    numpressed = 10;
    pressfound=true;
    column is now high, "0" has been pressed
    numpressed = 0;
    pressfound=true;
    column is now high, "." has been pressed
    numpressed = 11;
    pressfound=true;
    column is now high, "enter" has been pressed
    numpressed = 15;
    pressfound=true;
    digitalWrite(row4,LOW); //return fourth row
    low
    rowshigh(); //write all rows high
    return pressfound; //function returns true
    if any press found, otherwise returns false
    void definepress(){ //uses
    "lastnumpressed" and "timespressed" to define
    "letter"
    if (lastnumpressed==1){
    if (timespressed==1){
    letter='1';
    if (timespressed==2){
    letter='Q';
    if (timespressed==3){
    letter='Z';
    if (lastnumpressed==2){
    letter='2';
    letter='A';
    letter='B';
    if (timespressed==4){
    letter='C';
    if (lastnumpressed==3){
    letter='3';
    letter='D';
    letter='E';
    letter='F';
    if (lastnumpressed==4){
    letter='4';
    letter='G';
    letter='H';
    letter='I';
    if (lastnumpressed==5){
    letter='5';
    letter='J';
    letter='K';
    letter='L';
    if (lastnumpressed==6){
    letter='6';
    if
    (timespressed==2){
    letter='M';
    letter='N';
    letter='O';
    if (lastnumpressed==7){
    letter='7';
    letter='P';
    letter='R';
    letter='S';
    if (lastnumpressed==8){
    letter='8';
    letter='T';
    if
    (timespressed==3){
    letter='U';
    letter='V';
    if (lastnumpressed==9){
    letter='9';
    letter='W';
    letter='X';
    letter='Y';
    if (lastnumpressed==11){
    letter='.';
    letter='?';
    letter='!';
    if
    (timespressed==4){
    letter=',';
    if (timespressed==5){
    letter='\'';
    if (timespressed==6){
    letter='"';
    if (timespressed==7){
    letter='-';
    void
    incrementtimespressed(){ //increment "timespressed" until at max
    value stored in maxtimespressed for that lastnumpressed, then roll over to 1
    if
    (timespressed==maxtimespressed[lastnumpressed]){ //if at the maximum,
    timespressed=1; //roll over timespressed to
    one
    else{ //otherwise,
    timespressed++; //increment timespressed
    void dozero(){ //prints
    zero
    lcd.print('0'); //print 0
    lcd.setCursor(cursorx,cursory); //maintain
    cursor position
    dospace(); //space
    void dospace(){ //moves
    cursor forward once, wraps to next line if necessary, clears and returns to top
    of display if at bottom
    if (cursory==1){ //if on the bottom row,
    if (cursorx==14){ //if at the end of the
    row,
    cursorx=0; //define new cursor position as
    the upper-left corner
    cursory=0;
    lcd.clear();
    else{ //otherwise,
    cursorx++; //increment the cursor to the
    right
    else{ //if on the top row,
    if (cursorx==19){ //if at the end of the
    row,
    as the bottom-left corner
    cursory=1;
    else{ //otherwise,
    right
    lcd.setCursor(cursorx,cursory); //set cursor
    to defined location
    if (disablespacedelay){ //if the delay has
    been disabled,
    disablespacedelay=false; //reset its being
    disabled
    else{ //otherwise,
    delay(preventholddelay); //delay a bit
    void doclear(){ //clears and
    returns to top-left of display
    cursorx=0;
    cursory=0;
    lcd.clear();
    void dobackspace(){ //does
    a backspace, essentially the opposite of dospace
    if (cursory==1){
    if (cursorx==0){
    cursorx=16;
    cursory=0;
    else{
    cursorx--;
    else{
    if (cursorx==0){
    cursorx=0;
    cursory=0;
    else{
    cursorx--;
    lcd.print(" ");
    void textstorage(byte
    mode){ //contains functions for text storage
    if (mode==1){ //regular character storage
    phoneNumber[positioninphoneNumber]=letter;
    positioninphoneNumber++;
    // typedtext[positionintypedtext]=letter;
    //store letter that was printed to LCD in typedtext
    positionintypedtext++; //increment position in typedtext
    if
    (mode==2){ //do a space in stored text
    //typedtext[positionintypedtext]=' '; //set
    current position in typedtext to a space
    //positionintypedtext++; //increment
    phoneNumber[positioninphoneNumber]=' ';
    if (mode==3){ //does a backspace in the
    stored text
    //positionintypedtext--; //decrement
    positioninphoneNumber--;
    void outputserial(){ //output message and
    Serial.print("Phonenumber: ");
    Serial.println(phoneNumber);
    Serial.println("Message: ");
    Serial.print(typedtext); //print out all the
    // charremaining=(139-(positionintypedtext));
    //calculate remaining characters
    Serial.print(charremaining); //display
    if (charremaining==1){ //making sure that the
    plural is only used correctly
    Serial.println(" character
    remaining");
    else{
    Serial.println(" characters
    remaining");
    delay(preventholddelay); //delay a little to
    void mainMenu(){
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.print("To:");
    cursorx=3;
    cursory=0;
    lcd.setCursor(0,1);
    lcd.print("Text:");
    lcd.setCursor(0,1);
    void sendTextMessage()
    sms.SendSMS(phoneNumber,typedtext);
    delay(100);
    Serial.println("\nSMS sent OK");
    if i may ask why didnt you use the keypad.h i am trying to build something and i need to do the same thing to get the users email and address and i am using the keypad.h is it doable?
    I didn't use keypad.h as it obfuscates the use of the keypad, and frankly it's really easy to manually implement, as I did here (basically writing a row high, checking for a high signal on each of the columns (corresponding with a button press), and then writing the next row high, etc.). One major advantage of manual implementation is that it allowed me to share digital pins between the keypad and the LCD. So it's up to you which way to go, the code I developed for this project is dependent on the manual keypad implementation that I did, so if you would like to build off of my code, using keypad.h likely won't work out easily. You should be able to easily change the letters and such in the code as necessary to adjust my code to match your keypad.
    well first of all weldone for the tutorial.
    i've made it and it was actualy very easy.
    i have a problem conbining another code ( morse code encoder decoder ) to this .ino file.
    this is the libraries :
    https://code.google.com/p/morse-endecoder/download...
    and this is the code :
    #include <avr/pgmspace.h>
    #include <MorseEnDecoder.h>
    // Pin mappings
    const byte morseInPin = 7;
    const byte morseOutPin = 13;
    // Instantiate Morse objects
    morseDecoder morseInput(morseInPin, MORSE_KEYER, MORSE_ACTIVE_LOW);
    morseEncoder morseOutput(morseOutPin);
    // Variables dealing with formatting the output somewhat
    // by inserting CR's (carriage returns)
    long lastTransmissionTime;
    long currentTime;
    boolean transmissionEnded = true; // Flag to mark old transmission is finished
    // Minimum transmission pause time to insert carriage returns (CR)
    // Adjust depending on Morse speed. IE 13 wpm = 646 ms between words (no CR).
    const long transmissionPaused = 1000; // Suitable for 13 wpm?
    void setup()
    Serial.begin(9600);
    Serial.println("Morse EnDecoder demo");
    // Setting Morse speed in wpm - words per minute
    // If not set, 13 wpm is default anyway
    morseInput.setspeed(13);
    morseOutput.setspeed(13);
    lastTransmissionTime = (long)millis();
    void loop()
    currentTime = (long)millis();
    // Needs to call these once per loop
    morseInput.decode();
    morseOutput.encode();
    // SEND MORSE (OUTPUT)
    // Encode and send text received from the serial port (serial monitor)
    if (Serial.available() && morseOutput.available())
    // Get character from serial and send as Morse code
    char sendMorse = Serial.read();
    morseOutput.write(sendMorse);
    // Not strictly needed, but used to get morseSignalString before it is destroyed
    // (E.g. for morse training purposes)
    // Also write sent character + Morse code to serial port/monitor
    Serial.write(' ');
    Serial.write(sendMorse);
    Serial.write(morseOutput.morseSignalString);
    // RECEIVE MORSE (INPUT)
    // If a character is decoded from the input, write it to serial port
    if (morseInput.available())
    // Get decoded Morse code character and write it to serial port/monitor
    char receivedMorse = morseInput.read();
    Serial.print(receivedMorse);
    // A little error checking
    if (receivedMorse == '#') Serial.println("< ERROR:too many morse signals! >");
    // Local Morse code feedback from input if not sending Morse simultaneously
    if (morseOutput.available()) digitalWrite(morseOutPin, morseInput.morseSignalState);
    // Check if ongoing transmission (not yet transmission pause)
    if (!morseOutput.available() || morseInput.morseSignalState == true)
    // reset last transmission timer and flag
    lastTransmissionTime = currentTime;
    transmissionEnded = false;
    // Format output with carriage returns after a transmission pause
    if ((currentTime - lastTransmissionTime) > transmissionPaused)
    if (transmissionEnded == false)
    // Separate the transmissions somewhat in the serial monitor with CR's
    for (int cr=0; cr<2; cr++) Serial.println(""); // some carriage returns..
    // Finally set the flag to prevent continous carriage returns
    Well I've taken a look at the barebones example from the library you mentioned and it looks like it should be relatively simple to tack on the Morse code sending functionality (receiving would take some additional coding work, depending on how you wanted to accomplish it). I haven't tested it, but I would make the following additions to my code (line numbers are the current ones, they'll probably change as you add these lines of code in, so be careful)
    //towards the top of the code:
    //additional includes for morse, insert after line #9
    //add object for sending morse, here defined as pin 13, after includes
    morseEncoder morseOutput(13);
    //no additions needed to void setup() assuming the library default of 13wpm is used
    //add the following after lines 140 and 505
    morseOutput.write(typedtext);
    thank you for your response.
    morseOutput.write(typedtext); will not work.
    char* to char compilation problem
    instead i have used
    for (int i=0; i<(positionintypedtext); i++){
    char sendMorse = typedtext[i];
    Serial.print(i);
    Serial.print(sendMorse);
    Serial.print(morseOutput.morseSignalString);
    everything works in the serial window but no morse code.
    Did you try the for loop with the morseOutput.encode(); before the morseOutput.write(sendMorse); rather than after? That seemed to be the order it had to be in. Also just to make sure, what are you using to check for the Morse output?
    this is the code that i am using right now.
    Serial.println();
    Serial.print(i);
    Serial.print(')' );
    Serial.write(' ');
    Serial.write(' ');
    delay(preventholddelay); //delay a little to prevent continuous cycling
    it needs to be like that :
    otherwise i get nothing.
    Here, I threw together some code to add to mine that should achieve Morse transmission... without the uncooperative library. Tack the variables to the top and the functions at the bottom, and call sendmorse() at lines 140 and 505.
    i have just tryed it !
    did you try it on an arduino ?
    it actualy goes inside the for loop for just one time and then it realy freezes.
    it can not pass the for loop at all !
    i had a Serila.println(i);
    and it just comes up with 0.
    never goes again inside the loop at all.
    i will try to convert the ifs in to swich just in case that those are the delays.
    one thing that actualy works as expected is the time from the press of the " Enter " key until the time that goes inside the for loop.
    i excpected 5 seccond and it came up 5000 millis of deference, ech time i tryied it out.
    after that it just freezes.
