Repurposing a dead UPS in to a CNC Motor Controller Enclosure
 by Hextor
Featured
Just for clarification, I did not make a CNC motor controller out of a UPS; I’m only using the UPS housing as an enclosure for a commercial motor controller.
I purchased a table top CNC router from eBay, and the controller came mounted on a board.  I didn’t pay a much for it so it wasn’t too big of a deal.  But I soon found that the motor controller would be much better off in a protective case.   It would also be nice to have an on/off switch.   I initially planned on creating my own custom box using my router but I figured this would be more time effective and more durable.
This project is pretty easy but does require some soldering, drilling, and cutting.
I completed this project in about 4 hours, for a cost of about $5.00.
Step 1: Tools & Materials Needed.
The Tools Required for this project are pretty basic.
Multi-meter for finding out the pin-outs of the switches, and double checking wiring.
Screwdriver you may need both a Philips and a flat.
A Utility knife (razor blade) for cutting the Sintra.
Wire strippers these will get a lot of use in this project 4 wires X 3 motors  X 3 connections
Step Drill (or a regular drill bit) for drilling the vent holes and any necessary mounting holes.
Cordless Drill (optional) this makes taking apart the UPS very easy and quick.
A soldiering iron.
ntilak1 says: Feb 27, 2013. 1:29 AM
----- Original Message -----
Sent: Wednesday, February 27, 2013 1:31 PM
Subject: PRICE LIST FOR UPS , INVERTERS ,SOLAR UPS & Laboratory / Educational Kits For Engineering / Medical College Students -CONEX SYSTEM- www.conexups.com
To,
Purchase / Project / Maintenance Department:---
Dear Sir,
We Conex System,Pune, India www.conexups.com are leading manufacturer & service provider for following products for Last 20 Years.---
Inverters & UPS (Online and Offline) UP TO 450KVA
Solar Inverters, UPS (On grid & Off grid) -- UP TO 200KVA
PWM And MPPT Charge Controllers 12V to 360V.
STABALIZERS UP TO 1000KVA
Tubular Lead Acid Batteries .
Solar Panels
Solar Home / Street Lighting System ( CFL and LED )
Battery Chargers and Load Banks.
LED Lighting ,MNRE APPROVED SOLAR STREET LIGHTS
C.V.C.F./Static Frequency Converter
Lift/ Elevator Inverter,
D.C. Power Supply , C.V.T.,
WE HAVE INSTALLATION UP TO 450KVA UPS IN DIFFERENT LOCATIONS IN INDIA & WORD FOR CNC MACHINE, MEDICAL EQUIPMENTS, CALL CENTRES, DEFENCE EQUIPMENTS & OTHER CRITICAL LOAD
WE HAVE INSTALLATION UP TO 450KVA UPS IN DIFFERENT LOCATIONS IN INDIA & WORD FOR CNC MACHINE, MEDICAL EQUIPMENTS, CALL CENTRES, DEFENCE EQUIPMENTS & OTHER CRITICAL LOAD---WE HAVE ALSO INSTALLED 50 Hz. TO 400Hz. STATIC FREQUENCY CONVERTER FOR AIRCRAFT REPAIRS/MAINTENCE, DEFENCE, RADAR TEST FACILITY APPLICATION & HIGH CURRENT POWER SUPPLY FOR SUBMARIN APPLICATION ALL OVER INDIA & WORD.
Conex System, Mr.Nilesh Tilak ,Pune- State- Maharashtra-- India ;Phone- +912027111666 , Mobile- +919822068763 & +919421058306 ; Email: info@conexups.com ; nile5637@gmail.com www.conexups.com
PRICE LIST FOR PURE SINE WAVE ON LINE UPS WITH ISOLATION TRANSFORMER. in Rs.
2 KVA 1 Ph - 1Ph 144V 28600 ; 2KVA- 1PH 48 / 72V -rs.29700
3 KVA 1 Ph - 1 Ph 144V 31900;3KVA-72/96/120V --34500
5 KVA 1 Ph - 1Ph 144 / 180V --39000 120V --40700
7.5 KVA 1 Ph - 1 Ph 180 / 240V -46500 & 120V --49500
10 KVA 1 Ph -1 Ph 180V --55000 & 240V --60500
10 KVA 3 Ph -1 Ph 240V --71500
15 KVA 3 Ph -1 Ph 240V --99600 & 360V--94500
15 KVA 3 Ph -3 Ph 240V -116600 & 360V-112200
20 KVA 3 Ph -1 Ph 300V--123500 & 360V--119000
20 KVA 3 Ph -3 Ph 300V -141000 & 360V -135000
25 KVA 3 Ph -1 Ph 360V - 141000
25 KVA 3 Ph - 3 Ph 360V --153000
30 KVA 3 Ph - 1Ph 360V --146000
30 KVA 3 Ph - 3Ph 360V --158000
40 KVA 3 Ph - 3 Ph 360 V -199500
50 KVA 3 Ph - 3 Ph 360 V --242000
60 KVA 3 Ph - 3 Ph 360 V -299000
80 KVA 3 Ph - 3 Ph 360 V --399000
100 KVA 3PH-3PH 360 V --512000
120 KVA 3PH -3PH 360 V -585000
150 KVA 3PH-3PH 360 V --735000
180 KVA 3PH-3PH 360 V --1090000
3Ph - 3Ph INVERTERS/ UPS FOR LIFTS, AIR-CONDITION etc. without Battery
6 KVA 72/144/180v. --rs.55000
8 KVA 72/144/180v.--64000
10 KVA 144 / 180v. --75000
12 KVA 144 / 180 v.--79000
15 KVA 180 / 240v. --88000
20 KVA 180 / 240 v. -109000
30 KVA 240 / 360v.--129000
35 KVA 240 / 360 v. ---139500
40 KVA 240 / 360 v.--151000
1PH-1PH INVERTERS/ UPS FOR HEAVY LOAD LIKE AIR-CONDITION etc. without Battery
5KVA 120/180V
34,000
6KVA 120/180V
38,000
7.5KVA 120/180V
43,000
10KVA 180V
49,000
12KVA 192V
52,000
#Wide range of Input Supply Voltage to suit conditions
#Custom built design is possible as per User Specifications
#Latest Technology
#Compact size
#True ON-LINE topology
#High Performance; High Efficiency with near unity power factor
#Excellent Voltage Regulation and Transient Response
#Comprehensive and User friendly LCD Display with Mimic
#Support all types of Battery Systems
#Extended Run Time Facility
#Diesel Gen set Compatible
#Optional Intelligent Computer Interface
#Optional Auto By-pass facility
#Optional N + 1 (Parallel Redundant / Hot standby) Configuration UPS Systems
ON LINE UPS Range
1KVA – 10 KVA (1Ph - 1Ph)
10 KVA – 30 KVA (3Ph - 1Ph)
15KVA – 500 KVA (3Ph - 3Ph)
Services we can offer
Our Presales Services include Actual Load study and Sizing of Equipment and Battery ratings.
We undertake repairs / up gradation of Preexisting systems on mutually agreed terms
We undertake Disposal / Buy back of systems against new purchase
We can Design and Manufacture Custom built systems for a specific application. We can offer consultancy for devising the specifications for such requirements.
We have Designed and Supplied following Custom built Equipment other than our standard products
For Defense applications
400Hz Static Frequency Converter for Radar Test Facility
DC Power Supply 220 V – 80A for Submarine application
For Industrial Applications
Plate Formation Rectifier
Variable Power Supply 5 – 600V for Capacitor Manufacturing Plant
Battery Charger and Dischargers
Charge Controllers for Solar and Wind Power applications
Designed and Supplied 75KVA Inverter for Wind Power Generator
Other Products
Off Line Ups Systems
Range
1 KVA - 12 KVA (1Ph – 1Ph)
6 KVA – 150 KVA (3Ph – 3Ph) -- (FOR LIFT, AIR-CONDITIONS & OTHER HEAVY LOAD.)
Home Sine wave Inverter/Ups Systems
Range---650 VA – 4.8 KVA
STABALIZERS UP TO 2000KVA, ISOLATION TRANSFORMER, C.V.C.F., D.C. POWER SUPPLY, C.V.T., LED / SOLAR LIGHTING SYSTEMS
Conex System, Pune( India) Nilesh Tilak - Mobile no--- +91- 9822068763 & 9421058306 ; Skypee- nile5637
freddipal says: Oct 18, 2010. 12:34 PM
hi
what motor controller is that??
where did you buy it?how much?
thanks
musicmaneman in reply to freddipalFeb 25, 2011. 12:12 AM
I got a Univelop 3axis controller pretty cheap.
http://www.cncgeeker.com/index.php?main_page=product_info&cPath=1&products_id=1&zenid=84b768e2953c7e6f4a14ac0cdc7771d
Bought the stepper motors on E-bay.
Power supply from an old pc.
Hextor (author) in reply to musicmanemanFeb 25, 2011. 7:45 AM
I've seen those on E-bay, what do you think of it? My controller was a little expensive so I was looking to build another CNC machine using that controller. Let me know what you think please.
musicmaneman in reply to HextorFeb 25, 2011. 5:41 PM
So far so good. Easy to set up. Just hook the red, yellow and 2 blacks to it for power.
MatthewEnderle says: Sep 24, 2010. 3:40 PM
now you need to use sugar cubes to remove the "APC" logo off the front panel.
Paul Chops in reply to MatthewEnderleFeb 17, 2011. 3:44 AM
u can remove logo's with sugar cubes?????????
MatthewEnderle in reply to Paul ChopsFeb 17, 2011. 2:11 PM
yep you can!
http://www.instructables.com/id/How-to-remove-Logos-from-your-PDA--cell-phone-wit/#step1
Paul Chops in reply to MatthewEnderleFeb 18, 2011. 5:29 AM
i wish i knew this alot earlier
mahmoud rape says: Nov 10, 2010. 1:33 PM
I'm interests because i want to build a mini cnc
freddipal says: Oct 18, 2010. 12:36 PM
livingbios says: Aug 19, 2010. 11:23 PM
Good idea and great Instructable. Could you tell me the name of the connectors used for the motor connection?
livingbios in reply to livingbiosAug 20, 2010. 8:29 AM
Nevermind on the question, I found the answer.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
