Introduction: Rescue a Bluetooth From Laptop
second usage to Bluetooth module from a laptop designated to the bind.....
Step 1: What You Needed
a Bluetooth module from a old laptop(normally is in the up right or up center of the screen of the laptop,when you open the front part of the screen laptop)....
a USB cable with male part
necessary to soldering and some heat-shrink tubing
Step 2: How To.....
the module Bluetooth have a little connector(normally is withe).....cut this connector and preparing all wires
to soldering.....!!
you have 4 or five wires: use only red,black,withe and green....other...zack......
connect with a USB cable,with same colors( in all cables USB you have 4 colors:red,black,withe and green and
the usages is:black=ground;red=positive 5 volt;withe and green is for data).....
cover all connections with appropriate isolation.....
you have a possibility to place this component in a appropriate enclosure....free choice ....
on windows seven,at the moment of you connect in USB,windows search automatically all drivers to permit the usage on your PC.....
Step 3: Transfer Data..
use Bluetooth to transfer data,music or other from/to PC and all other compatibles machines......
have fun and thank's to watch my instructable.....
