If someone falls into a pool, it's usually more humourous than a cause for alarm. Even if they are hurt, as long as someone sees them, they can be pulled out quickly enough to prevent drowning.
If they fall from a boat, or into a fast-flowing river, it's more serious.
If someone falls off the back of a boat doing 6 knots, Instantly they are too far away to climb back. In ten seconds they are 30 metres away - too far to throw a line. In five minutes they are nearly a kilometer away, about the apparent size of the planet Venus. In 30 minutes in cold water, they may die from hypothermia.
Remove these ads by
Signing UpStep 1Equipment Required
The following items are useful, at the least. They may be required equipment in some jurisdictions and for boats of a certain size.
- 60 metres of floating line
- two life buoys, or medium sized floats
- a marker buoy
- a boarding ladder (should extend 80cm into the water)
- a sling, or harness
- davits or spar with block and winch
- floating lights
- PFD (personal flotation device or life jacket), one per person, with light and whistle
- GPS receiver
- VHF radio
- Heaving line (flaked into a soft bag for an effective throw)
- powerful flashlight or spotlight
- swim fins
The purpose of the marker pole is to be visible in waves several feet high. Typically the pole is sold with a code "O" flag ("man overboard") in a cover. Mine was lost and replaced with a scrap of fabric.
The small floating lights are suitable for attachment to a PFD. The larger one is intended to be attached to the life buoy, but may be used separately. The small ones are activated by contact with water, the larger one by orientation (when stored inverted, it is off).
The sling shown is actually intended for someone to sit in while working aloft, not as a rescue sling. But it is strong enough, and easy to secure around a victim.
A block and winch are useful to retrieve an injured or unconscious victim. On a sailboat, the main boom may be used as lifting tackle as shown. On a powerboat, a boat davit may be available. Even on a relatively small boat, the deck may be a metre above water level so a "pool rescue" technique is unsuitable.
(It would probably be better to stow the bicycle somewhere else. However, it is not actually preventing easy removal of the lifebuoys. The buoy shown needs repair, but is fully functional - anything to hand is better than the best equipment stowed out of reach)
except for the turn : any object thrown in the water could have done the trick… but both kids enjoyed the experience
otherwise the crew does not perform his duty = someone constantly watchi g the mMOB with arm stretched in his / her direction, compass route checked and remembered as soon as the crew falls into the water sails being already furled this solves most of the problem but does not reflect true to life conditions (eg. slacking the sail, starting the engine, checking there is no line overboard that could snag the propeller which would seriously jeopardize the mob's chance of survival), immediate call of the CG on the VHF, and using the equipment you designed for that : the long tether that was supposed to allow the mob to get a quick link with the boat, the recovery sling (most of the tie a mob is shocked if not injured, and will not be able to climb the ladder so gallantly (but in less than in emergency) offered by the crew member, the hailyard at the end of the boom : all this should be done in less than one minute.
It can be done even with a short handed crew… but the solution is know your boat, have it ready, and drill, drill, drill all the time !!!…
I know it's not that easy with friends who are here on vacations, but better bother now than sorry later
when I can I'll post my own recovery procedure with my own boat
thank you anyway !!!!
The Williamson turn looks really effective. However, I am more a sailor and on a sailboat this is impossible. However, there are other options.
And a last remark from my side: Many boating / sailing GPS receivers have a mark button to set the current position as waypoint. Usually it gets the name 'MOB' (Man Over Board) by default. Simply press buttons 'mark', then 'goto' to see where to find your victim.
Airspace V - international hangar flying!
http://www.airspace-v.com/ggadgets for tools & toys
