Researching a Research Paper Quickly and Effectively
 by AngryRedhead
Contest WinnerFeatured
Step 7: The Process Is NOT Linear
Writing a research paper is not a linear process. I have yet to research a paper, pull all the necessary research, write the paper, and not return to researching some more. As you write, you will discover unanticipated gaps.
Example: Exactly how relevant is fashion to people? I must show that fashion is indeed important in a substantive way with at least some figures and examples. I know it isn't just important to "fashionistas" and researchers.
When these gaps occur, write a note to the side explaining the gap and what you need to discuss. You can fill the gaps as they occur, or you can continue writing and fill the gaps at the end, or you can do some sort of combination.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
