Introduction: Reshaping Your Spent Nerf Darts, Don't Buy More, Recover the Old Ones.
Nerf darts can give you so much fun, especially the new Elite ones, but any kind of dart will begin to crush and bend after intense use. Darts gradually become more thin. Thin darts enter too softly on chambers so they don't seal well on the chambers and air pressure is lost resulting in a decrease in shooting range. On external loading guns thin darts will even slip out of the barrels, specially since the air restrictors push against them. Revolvers jam easily when darts slip out of their barrels.
Don't buy more darts, follow this simple procedure and you will reshape those spent darts.
This procedure works on every kind of dart: sonic, streamline, suction, Elite, etc.
Step 1: Select the Darts.
The first step will be to select the spent darts. Take an external loading gun like the Triad, Jolt, Roughcut, Strongarm, Nitefinder, Maverick, etc. Take a dart and push it into the barrel. Remember how it felt when it was new? It must feel tight on the barrel.
If it feels too easy or loose then it is too thin. Bent darts also must be reshaped.
Step 2: Reshaping the Darts.
Take a metal pot and fill it with water. Heat it until the water boils. Use a pair of pincers to dip the darts in the boiling water for 1-2 seconds. Don't let the darts touch the bottom of the pot. Place the darts on some container to let them cool and dry. Don't squeeze them while they are hot or they will deform again.
Darts deform when the air bubbles in the foam get crushed. When you heat the dart the bubbles expand again, expanding and reshaping the foam.
Be careful about how much time you dip the dart. If you heat it too much the foam will expand more but the air bubbles will puncture. When the dart cools it will become very thin. See the photos of the orange dart.
Step 3: Finished!!!
You are done!! Your darts should be as thick as new. They will fly farther and faster and fit tight in the barrels. You can reshape your darts about 2-3 times, after that the foam will become too soft and the dart will end its useful life. But you will double the life of your darts.
Happy blasting and play safe!!
If you liked this instructable please leave me a comment.
I have some uploaded music on other site, if you want to see more about me. http://musescore.com/user/62111
