3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Resin Jewelry Tutorial with John W. Golden part 1
video Resin Jewelry Tutorial with John W. Golden part 1
A how-to video for using epoxy resin, silver-plated rings and pewter pendant trays to create jewelry from reproductions of your artwork. Part 1 of 3.
See John's finished rings, pendants and artist's reproductions at johnwgolden.etsy.com.
12 comments
Aug 12, 2011. 5:50 AMBGR8FUL says:
Where's the video?
May 1, 2011. 1:05 AMnotthebritishchildren says:
Great 'ible, terrificly detailed! Reminded me of my third grade teacher, she called it "Modge Podge", too. Thanks bunches!
Mar 7, 2011. 6:11 AMporcupinemamma says:
Beautiful! So cool! Could you please type out your website? I can't read fast enough on the video
Jan 24, 2009. 9:38 PMon_bourbon_street says:
John, Thank you so much! I've been designing and making my vintage bottle cap necklaces for about 6 months now, but every so often I was running into the problem of the resin causing that 'bleed' effect on certain images. It's especially aggravating when it happens to 10 or more at a time, and I have some big orders coming up. Never thought to use mod podge, but I've been wracking my brain over what I can do to fix the problem.
And Blakeney is right, those 1" hole punches are Sah-WEET! I don't know what I'd do without mine. They're only about $6, and you can find em at Michael's.
If you'd like to see what I do, take a peek at my site:
Chromatic Creations
You're a lifesaver!
Dana
Feb 7, 2011. 6:10 PMlukev2 says:
u from nawlins?
Sep 10, 2010. 9:33 AMgrofaz says:
Thanks for the share! Great instructable. I want to make a few custom pendants, where can I find the pewter pendants and rings that you use? Thanks!
Feb 5, 2010. 6:34 PMchrissy5529 says:
Do you or does anyone know where I can order plain metal resin trays without any loops or ring backs attached to them?  My fiance and I are making cuff links for his groomsmen and we have purchased the cuff link part but have been been unable to find plain old resin trays without the jewelry attachments.  Our cuff links are 15mm wide so we need something this size or slightly larger.  Thanks,
Mar 12, 2010. 8:07 AMcaseyandlizzie says:
I am making cuff links for my wedding too....I found them on etsy from seller brass gold beads:
http://www.etsy.com/view_listing.php?listing_id=42563501&ref=sr_list_2&&ga_search_query=bezel+cup&ga_search_type=supplies&ga_page=&includes[]=tags&includes[]=title
Good luck!
Jun 7, 2009. 3:14 PMpolishboy021 says:
this is amazing! thank you!!!! :)
Feb 20, 2009. 1:02 PMlisann says:
Ditto what on_bourbon_street said! Thank you for the Mod Podge suggestion. You've saved me from going completely gray over the same issue. About the alcohol--it does work to clean up the resin. Also, I've had some pieces that had surface issues, such as fingerprints. You can wipe the surface of the piece with a paper towel dampened with alcohol (I always use denatured, not sure if it makes a difference) and it will slightly dissolve the surface and you can get rid of the fingerprint. The trick is to use something non-linty and to only do one or two swipes at a time. Any more than that and it can get gooey and create more problems than you had before. It's definitely a good idea to practice. Thanks again!
Dec 15, 2008. 2:29 PMBlakeney says:
Thank you very much for an informative tutorial. I had started making a few pendants with my own artwork, but have not tried to sell them yet. FYI - A 1" circle punch (or a square punch in the size you need) can be very helpful and is much faster than cutting images by hand. Thanks again, and I love your robots!
Jun 15, 2008. 5:28 PMneubaten says:
how do you get the video to play? theres no video window or dialog box or anything, sorry im a bit of a computer retard
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
75
Author:johnwgolden
