Resin Tray Care
734
Posted
Introduction: Resin Tray Care
Taking good care of your resin tray is important for successful prints.
This guide will take you through how to maintain and care for your resin tray.
Step 1: Resin Tray Elements
The resin tray is made up of the following components
  1. Resin tray
  2. PDMS window
  3. Glass window
  4. Gasket
Resin Tray
The resin tray is made from amber polycarbonate. The amber color blocks blue light and prevents the resin from curing.
PDMS Window
The PDMS window is where the parts is built. PDMS stands for Polydimethylsiloxane and it is a member of the silicone family.
Glass Window
The glass window is the substrate that the PDMS window is stuck to, it provides rigidity to the PDMS window assembly.
Gasket
The gasket is used to create a watertight seal between the glass window and the resin tray.
Step 2: Remove the Resin Tray
WARNINGWhen handling resin, wear protective gloves,
protective clothing, and eye & face protection
  1. Remove the resin tray
    Note:
    Always remove the build head before removing the resin tray. Otherwise resin could drip onto the optical path of the projector!
Step 3: Pour Away Excess Resin
  1. Pour all the excess resin into a storage container
    Tip:
    You shouldn't pour used resin back into a fresh resin bottle. We recommend you keep an old resin bottle on hand to store used resin.
Step 4: Clean the PDMS
  1. Using a gloved finger, gently rub the surface of the PDMS to remove any cured resin stuck to the PDMS
    CAUTIONNever use any tools on the surface of the PDMS. If the PDMS is scratched or damaged you will need to replace the resin tray
Step 5: Clean the Glass Window
  1. Now that the PDMS is clean, flip the tray over and using an Isopropyl Alcohol swab gently clean the underside of the glass, removing all smudges and smears
    DANGERKeep Isopropyl Alcohol swab away from heat/sparks/open flames/hot surfaces
  • Epilog Challenge 9
    Epilog Challenge 9
  • Sew Warm Contest 2018
  • Paper Contest 2018
    Paper Contest 2018
