Resole Your Birkenstocks
52,668
31
Published
Introduction: Resole Your Birkenstocks
About: A website dedicated to providing the materials for making and repairing your own footwear.
A simple way to resole your Birkenstock Sandals. All materials and instructions from DIY Footwear
Tools Needed:
- An old dull knife
- Sand paper
- Barge Glue
- Popsicle stick
- Chalk
- Box cutter
Materials Needed:
-Rubber Birkenstock Resoling Material.
Step 1: De-Soling
1. This first step is important to do well, because any left over old sole material will make glueing on new sole more difficult. Normally the glue that shoe companies use on footwear is very strong so take your time removing it. Slowly work around the edges of the sole to pry and cut it free of your Birkenstock.
We suggest using an old kitchen knife or something that is strong enough to dive between the sole and Birkenstock and pry apart the bond. Once you remove the sole, sand off any remnant pieces of old rubber stuck on the Birkenstock. You will want a clean surface to glue your new sole to.
Keep your old sole in tact to trace in the next step!
Step 2: Cutting Out New Birkenstock Sole
1. Use the old sole you removed off your Birkenstock from Step 1.
2. Place it on a sheet of new Birkenstock sole material and trace with chalk. Use a sharp chalk edge to hug to the outline of old sole as closely as possible.
3. Find a piece of wood or cutting board to lay beneath the new Birkenstock sheet. Then use a box cutter and slowly cut out along chalk outline you created. Be sure to cut along the inside edge of the chalk line.
4. Once cut, flip the sole over - traction side up. Go back to the heel area and smooth out rough edges with the the box cutter. Next use 120 grit sand paper to buff out the edges and make things pretty!
Step 3: Glueing + Finishing
1. Make sure both your old Birkenstock's and new soles are ready for glueing. Do a final sand-prep on both surfaces that will be glued together. This will create more surface area for your glue to bond.
2. Use Barge Cement and a popsicle stick to spread glue on both new sole cutout and your old Birkenstocks. Spread evenly and do not let puddle. Let glue dry (10-15 minutes).
3. Re-apply a second layer of glue if some of it was absorbed into material surfaces. Wait and let dry again.
4. Bond your new sole to your Birkenstocks starting at the heel. The glue bonds quickly so there is little margin for error - be sure to line them up correctly!
5. Use strong rubber bands to keep the sole pressed up again the Birkenstock. Let dry for at least 12 hours.
6. Remove the rubber bands. If needed, sand out any glue on the edges of your rubber sole to make it look nice!
    • Stick It! Contest
      Stick It! Contest
    • Casting Contest
      Casting Contest
    • Oil Contest
      Oil Contest
    i live in ireland, could you tell me where i get birkenstock resoling material? i went to the birkenstock shop and they said that they do not do them
    3 Comments
    Did you heat the shoe before peeling off the sole? I heated mine at 200
    degrees for 10 minutes and still can't get the sole off. It's on there
    really good. I tried using a steel putty knife, but no luck. Any ideas I
    can try? Thanks!
    ThomasL180, if you haven't fixed those shoes yet, here's how you could get started: Rather than taking the sole entirely off, cut it down to a thin layer and attach the new sole to that layer. Go get a dovetail saw or another very fine-toothed saw. Get some painter's tape and use it to make a precise line around the edge of your sole, so you can see that you're making a perfectly level cut. Here's what I did with a heel repair to illustrate how to tape so you have a precise edge to make that cut, except that you're removing the entire sole.
    I am just in the middle of resoling my white London Birkenstocks. The London style is no longer available in white. I did however do something differently than you did. I took a pair of Birkenstock Betula sandals and removed the sole. Then cut them down a little to match my soles. Thanks for doing this intractable and showing me how to do this myself.
