Introduction: Restore a Rusty Toolbox
I recently picked up a rusty old toolbox for a few dollars at a thrift store.
It was structurally solid and didn't technically need any work to make it useful, but aesthetically it was in pretty poor shape so I decided to give it an upgrade.
Step 1: Rough Condition
The exterior paint was flaking off and the metal was rusty underneath.
I quite liked the toolbox in this state, to be honest, and was tempted to just leave it. But in the end I thought it would be a fun project so I went ahead with the makeover.
Step 2: Take It Apart
The drawers and drawer slides were removed. The slides were supported internally with little panels that I was also able to remove.
The handle and latches were riveted in place. The rivets were drilled out from the inside and these parts were removed.
Everything was scrubbed with degreasing soap (I used simple green) and hot water, thoroughly rinsed and dried.
Step 3: Strip Paint and Rust
I decided to strip the paint and rust mechanically.
What ended up working the best for this were abrasive paint and rust stripping disks.
This process kicks up a lot of nasty stuff, so be sure to wear protective equipment. I wore goggles, breathing mask, and ear muffs.
Step 4: Clean and Prime
The case and drawers were vacuumed out to remove all the rust and paint dust, and then wiped down with a clean rag dampened with denatured alcohol.
Once they were perfectly clean, I did not touch them with my bare hands to keep them free from oils prior to painting.
The case and drawers were then painted with Rustoleum professional primer.
Step 5: Paint
After priming, I painted the case and drawers with several thin coats of "Safety Blue" paint.
Step 6: Drawer Slides
The panels that hold the drawer slides were a little rusty along the bottom edges. The rust was removed with a wire wheel using my rotary tool, and then these areas were painted with primer.
Step 7: Handles and Latches
The main handle parts and latch parts were made of plated metal, and the drawer handles were made of aluminum.
The plated metal parts were a little rusty with some of the plating flaking off. I used a wire wheel in my rotary tool to remove the surface rust and any loose plating, and then hit these parts with a very light coat of Rustoleum chrome paint.
The aluminum handles were cleaned but not polished.
Step 8: Masking
I decided to add some racing stripes, just for fun.
I waited a full 24 hours after painting the blue coats to do the stripes.
I began by laying out painter's tape very carefully to mask off some internal stripes I wanted to stay blue. Masking paper was added to cover larger areas as well.
Step 9: Paint Stripes
A coat of blue paint was put down first. This seals the edges of the tape and prevents any bleed-under from the final coatings of white.
I waited about 10 minutes after painting the blue, and then added light coatings of white every few minutes until there was a solid white coating.
When I paint stripes and two-toned things like this, I prefer to remove the tape immediately when the paint is still wet. So that's what I did.
It's a delicate process and care must be taken to avoid touching the wet paint, or having any errant strips of tape or masking paper touch it.
Step 10: Wait!
This is the hardest part of a project like this. It's tempting to just wait till the paint is dry to the touch and replace all the hardware . . .
But I recommend setting the recently painted items in a clean, non-dusty place and just leaving them alone for a few days for the paint to harden.
Step 11: Reassemble
When you can't wait any longer, go ahead and reassemble the parts.
I slid the drawer slide panels in place and added the slides with fresh grease. The drawer handles were re-affixed and the drawers slid into place.
Step 12: Latches and Handle
For the latches, I reinstalled them using pop rivets.
I didn't think pop rivets would be sufficient for the top handle, so for this I used some small bolts.
Step 13: Drawer Liners
I got some cheap drawer liners which I cut to size and placed in the drawers.
The kind of liners I used (from HF) are rolled and don't lay flat. Hitting them with heat from a heat gun until they relax and lay flat seems to help. Just be careful, if you hold the heat too close it can melt them.
Step 14: Load It With Tools
I like the way it turned out, and it's ready to be loaded up with some tools.
Thanks for taking a look!
