Restore an Old "Balkan" Bike
1,863
16
5
Published
Introduction: Restore an Old "Balkan" Bike
Balkan bikes have been around in Bulgaria for years no longer produced they have been pushed for newer models.They are very sturdy bikes and are foldable (some models).
Step 1: Find a Project Bike
I found this bike for 15lv which is about 10$ or 7 euro.Which is a steal but it will need a lot of work.
Step 2: Strip the Bike
Strip every part you can.I couldn't get the chain off since i don't have the tool but i wasn't that big of a problem.
Next you will need to strip the paint.I mostly used chemicals but a wire brush was needed on some spots.
Step 3: Priming and Painting
Prime the bike and paint the color you want.I went with plain mat black.
Step 4: New Parts
Since the bike is old some parts are beyond saving and need to be replaced.This type of Balkan bike does not have break livers and pads if you wanted to brake you start pedaling back and that blocked the back tire witch was effective but not for me.I got a donor bike for cheep and dismantled it for parts such as brakes, tyres ,handles and some other small parts.Some parts need to be bout new such as pedals,break lines,crank set,chain ring,seat post and a new seat .
Step 5: Assemble
Start assembling you bike.I put the brake lines inside the frame so its less messy.Had to get creative whit the brakes since there is no room for them and they went on the bottom but it works fine.
Step 6: Ride
Ride your bike :)
    • Oil Contest
      Oil Contest
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
    5 Comments
    That back brake......eeeyukk. You need to make a steel spacer plate with 2 holes, to make the pads reach the rim (one hole for the frame between the seat stays, the other for the caliper brake. Do this, and you'll be free to use hi-pressure tires with thinner side walls for more speed.
    I have never seen a brake mounted in such a way that the pads grip the tire instead of the rim. Maybe it is OK but I think i would ask some bike shops.
    No its bad for the tires but i do it some times because it stops you on the spot but i its not for every day riding
    Браво. Добра работа колега.
