Restore and Maintain Butcher Block Counter
2,630
80
Published
Introduction: Restore and Maintain Butcher Block Counter
I decided to try using my counter top as a cutting and prep surface. My butcher block island counter had been stained, so I removed the stain and prepared the surface.
Step 1: Stained Surface
A dark stain remained on the cutting surface.
Step 2: Planer
I started with a planer to remove the top layer of wood. The stain penetrated fairly deeply, so this process allowed me to remove large portions quickly.
Step 3: Complete Planing
The surface was a little rough after planing and in the places with many knots a few gouges remained.
Step 4: Belt Sander
A belt sander with 80 grit paper smoothed the surface. Because there was a snow storm and I have no garage I created a clean room with painters plastic and sealed it off. It was like a sand storm inside, but contained all the dust, keeping the surrounding room spotless.
Step 5: Block Sander
I hand sanded with a block and a few finer grit papers, then wiped the surface clean with a damp cloth.
Step 6: Oil Surface
I experimented with mineral oil and mineral oil with wax. Both seemed to work well.
Step 7: Restored Butcher Block Surface
Surface in restored condition.
Step 8: Maintain the Surface
Scrub the surface with a hot soapy water.
Step 9: Rinse With Hot Water
Rinse.
Step 10: Sanitize With Vinegar
Use vinegar to sanitize the surface and let stand for a while.
Step 11: Citrus Salt Scrub
Make a paste with lemon juice and salt and scrub the wood surface. This helps with odors. Allow to dry overnight.
Step 12: Oil Surface
Remove salt from the surface and wipe clean. Coat with mineral oil.
Step 13: Complete
Time to cook.
    • Oil Contest
      Oil Contest
    • Water Contest
      Water Contest
    • Stick It! Contest
      Stick It! Contest
    3 Discussions
    Dwargh
    2 years ago
    Amazing tutorial! I want a Butcher block counter NOW in my kitchen!!! :o
    Wow! What a difference! I love your spice rack as well
    You did an outstanding restoration job of the top, I would not ever consider putting a knife to it now. We use a simple cutting board for kitchen knife chores, and go one step further: we request double paper bagging at the food store, and cut the bags into squares, using them to line the top of the cutting board. They're disposable and much more sanitary than direct contact with the cutting surface.
