Restore and Modify an Original DMG Gameboy
Introduction: Restore and Modify an Original DMG Gameboy
Hack It! Contest
Runner Up in the
Hack It! Contest
Released in 1989, the DMG (Dot Matrix Gameboy) was the first Gameboy Nintendo ever released.  It’s a lot of fun to mess with, so here’s a quick guide of my experiences taking apart, restoring, and modifying the DMG with an awesome new backlight.
The Gameboy I had was in fairly good condition, with the exception of several vertical lines through the display.  After some research, I learned this is usually due to a faulty display connector, where the solder connections have weakened and eventually separated from the top layer of the display circuitry.  Using a soldering iron, I learned that we can reflow (that is, remelt and reconnect) this broken solder below the connector.  It’s not that hard, and fixes what is perhaps the most common issue with these Gameboys.
Step 1: Taking It Apart
The first step is to remove the back cover of the DMG.  There are six screws, and depending on when your Gameboy was made, they are either going to be triwing or phillips.  Triwing screws, for those of you unfamiliar, are Nintendo’s favorite way to make opening their products just ever so slightly more irritating.  If you don’t want to spend a couple dollars on a triwing driver, you can do what I did and use a small flathead in one of the three slots in the screws.  It’s not super difficult, but you definitely want to be careful to avoid stripping the screws.  There’s four obvious ones on the back of the Gameboy, and two inside the battery compartment.  You’ll need to remove all of these.
Once you take those screws out, don’t pull the Gameboy apart quickly.  There’s a fairly short ribbon connector connecting the screen half of the Gameboy to the circuitry half.  Carefully hinge unit so the screen half is face down on your desk with the circuitry portion sticking vertically upward.  You could disconnect the ribbon cable at this point (it’s a ZIF socket, so the connector just slides out), but I didn’t want to bother having to reconnect it when I was done.  You can do this repair quite easily without having to put this connector back in.
Step 2: Removing the Circuit Board
Next, you have to remove ten screws holding the display board onto the front case.  From this point forward, all the screws we’ll be dealing with are just phillips.
Remove those ten screws, and gently wiggle the front board away from the case.  Don’t be too violent here, the board is thin enough you could put some stress fractures in it if you’re not a little careful.  Eventually the board will come free.  If you’re having some real difficulty, double check that you have removed all ten screws.
It’s a good idea at this point to place a slip of paper between the top board and bottom board so that you don’t short anything out you don’t want to. Once you’ve done this, put the batteries in the Gameboy, turn it on, and change the contrast with the knob on the left side of the display until the whole thing turns black (with the exception of the lines we’re fixing).  You can see here that the act of removing the display from its housing was enough to cause even more black vertical lines to appear.  We’ll fix those in just a second.
Step 3: Fixing the Vertical Lines
Just below the display there’s usually a thin black rubber strip attached to that brown film.  For me, that strip stuck to the plastic Gameboy case when I took the board out, but from looking around online it seems like most boards will still have that slip attached.  Using a razor blade or sharp knife, remove that rubber strip and the adhesive below it.  It should peel off kind of like a sticker.
Now we fix the display!  Heat up your soldering iron and gently rub it black and forth on the brown part of the connector just below.  If the lines are towards the left side of the display, heat the left side of that connector.  Don’t venture onto the white plastic, or else you’ll get a sticky mess.  I believe the brown ribbon connector is kapton film, which is incredibly heat resistant (it’s used in heating elements), so don’t worry about heating it too much.  That being said, you shouldn’t need a whole lot of heat.  Don’t spend more than 3 or 4 seconds on any given spot.
While you’re doing this you may notice that more lines appear while you’re heating the connector.  This is just some product of the solder reflow process.  Once you stop the heat and the solder solidifies, more lines should begin appearing.  I was able to get my display 100% working again, and it looks like this repair has about a 100% success rate if you do it correctly.
If fixing the lines is all you wanted to do, you’re done! Go ahead and reassemble your Gameboy, and don’t forget to reattach that rubber strip.  It helps keep the connector from experiencing the stresses that caused it to fracture in the first place.
Step 4: Adding a Backlight Part 1
Next I thought I would add a backlight to the Gameboy’s screen.  This was a lot of fun, and I’m sure any 90s kid would have killed for this when the Gameboy was still super popular.  I got my backlight module from a great company called Kitsch-Bent.  You can get your backlight in wide variety of colors, and even buy an inverted screen!  Truly an awesome source.  They also sell different colored front lenses and buttons.
First, remove the two screws on the brown connector just below the display.  This will free up the display, and allow you to take it out of the white plastic frame.  After gently prying the display out of its frame, use a sharp pair of snips to cut off around a centimeter of the thin plastic frame below the display.  This will give us room to pass wires beneath the connector.
Next is the only tricky part of the process.  Using a sharp knife or razor blade, you have to remove both the reflective back layer and polarizing film from the LCD.  If the display still looks a green color after you’ve done this, you have only removed the reflective film and not the polarizing layer.  Try again to catch the edge of the film, and slowly peel it off until you are left with a transparent LCD.
In the third photo I’ve only begun removing the reflective film.  You can tell because the display still looks green behind it.  Go back and make sure you’ve removed that green tinted layer.
After doing this, remove the protective cover from the backlight module and slide it underneath the display in the plastic frame.  Route the wires through the slot you cut earlier.
Step 5: Adding a Backlight Part 2
The final step is to wire this panel into the Gameboy’s circuitry.  Luckily there’s a great voltage source just below the LCD that’s easy to tap into.  Solder the two wires (in my case blue [voltage] and black [ground]) as shown.
Screw the brown connector back to the main board (be careful, the mounts strip easily), and you’re done!  Go ahead and reassemble your gameboy, making sure that your new wires don’t get in the way of the d-pad or buttons.
When you turn on your gameboy, you should be treated with a new backlit display!  I also used this opportunity to replace the front cover lens with a new, less scratched one.  Finally, I replaced the buttons, just to be fancy.  After removing the front cover from before, you can just replace the buttons with the new ones you’ve bought.  They pop right out.  The front lens was originally tacked on with a bit of glue, and can be pried off with a sharp knife inserted underneath one of the edges.  My new lens came with an adhesive back that just stuck right on.
I hope you found this helpful — thanks for reading!
    • Pocket-Sized Contest
    • Science of Cooking
      Science of Cooking
    • Pro Tips Challenge
      Pro Tips Challenge
    Awesome tutorial. Fixed mine following step by step. I was a little bit worried my soldier iron was too hot so I set it up not too hot but it seems that the kapton connector is really heat resistant so I switched again to hot soldier iron temperature and it was done. I had to repeat process couple of times, I noticed it fixes also if you almost do not touch with solder iron the kapton film as the heat "passes" to the connector. Worked like a charm, now I'm again an happy DMG Gameboy owner.
    Might I just recommend one site: Kitsch-Bent.
    heard of Gameboy Classic DMG power adapter?
    please check:
    Just finished doing mine as the backlight came today! Thanks for the great tutorial, but now im having trouble with my new screen (protector thing on case) its too reflective, is there anywhere i can get non reflective ones or anti reflective film to put over it?
    thanks! this worked perfectly! i just wish i could find a UK seller for that backlight!
    Question: My game boy starts up but it won't go any farther than the Nintendo logo and instead of the logo is just a black rectangle. so do I do what this Instructable suggests or is there a different remedy?
    Clean the contacts of the gameboy AND the cartridge with alcohol and a Q tip.
    Any ideas to how to get the backlight to work on an older Gameboy DS? My son got one at a rummage sale and I haven't been able to get the light to work. Appreciate any help anyone can give me. Thanks. Will need to bookmark your instructable for future reference -- still have 2 working Gameboy colors.
    Nice! Not so often anymore can you crack something open and see so many throughhole components :P (that actually only really applies to consumer electronics, there are a decent number of power supplies with throughhole stuff.)
    Very nice mate! Random Question: do you reckon a coloured backlight can be added to my old GameBoy Pocket just as easy? would they be much different inside besides the size?
