Restoring Old Chisels Using Electrolytic Rust Removal.
3,218
36
14
Posted
Introduction: Restoring Old Chisels Using Electrolytic Rust Removal.
I had some old cold chisels inherited from my father gathering rust. Using electrolytic rust removal and a bit of spray paint I will show you how to restore them to their former glory.
Step 1: Watch the Video
Step 2: Materials
Materials you will need:
Rusty tools
Voltage source (battery charger)
Non conductive container
Sacrificial anode
Wire (for wiring tools) cathode
Soda Ash or Bicarbonate of Soda
Fresh Water
Time
Step 3: Electrolytic Rust Removal
Wire the tools and connect to negative of voltage source
Connect positive to the sacrificial anode
Mix the Soda Ash (Bicarbonate/ washing soda) in fresh water
Cover tools in non conductive container with water solution
Turn on voltage source
Wait
WARNING: DO NOT PUT YOUR HANDS IN THE WATER WHILST CHARGER IS ON AND/OR CONNECTED!!
Step 4: Removing and Cleaning Tools
SWITCH OFF POWER SOURCE!!
Remove tools from solution
Remove wire
Rinse in freshwater using scrubbing brush for a few minutes
Step 5: Metal Cleanup
Clean up metal burrs on bench grinder
Step 6: Spray Paint
Finish in the colour of your choice
  • Gluten Free Challenge
  • Sew Warm Contest 2018
  • Epilog Challenge 9
    Epilog Challenge 9
14 Comments
I've been doing electrolysis for years and just recently hit on a great product to use as an electrolyte. Rust Wash by Rust Check. It blows the rust off in a fraction of the time. No fumes, but it does foam up quite a bit.
Hey Friger
looks like a great product. Gonna try it and will post a video. Thanks for the suggestion
I'm not 100% sure but I suspect this may be urea hydrochloride - made from urea and hydrochloric acid.
Electrolysis is supposed to convert as much of the rust back to steel as possible. I think the rust wash is supposed to remove the rust instead of converting it.
I think you may want to research that a bit.
"The idea of using electricity to convert rust back into iron is not a new one, and electrolysis has been used for metal restoration by collectors and archaeologists for decades and the results can be very impressive, with shiny metal being visible after proper treatment." http://myweb.tiscali.co.uk/andyspatch/rust.htm
"Easy to use; quickly loosenes and dissolves rust from metal surfaces." http://www.rustcheck.com/product/enviro-rust-wash/
This looks a lot more fun than vinegar and steel wool!
I do not understand the wiring and the 'sacrificial anode'. I see that all the tools to be cleaned are wired together, and the black (-ve) cable is attached to that wire. I do not see what the red (+ve) cable is connected to, and how whatever it is connected to reaches inside the electrolyte bath. Just a piece of wire that loops over the edge of the tank and into the bath?
Any recommendation for type of wire? Copper power line, telephone wire, metal coathanger?
Thank you! A friend gave me about 100 pounds of old metal shop tools, and it's killing me to just let them sit there.
Hi bodgerjfr
simply, the negative is attached to the tool from which you wish to remove the rust. The Positive is attached to a piece of scrap iron; both of which are submerged in the bath. In my example, all the tools are hung on a bus-bar. Any heavy duty wire can be used except stainless steel - the heavier the better. You can use a coat hanger, but clean of the galvanized coating first. I hope this helps and good luck with getting your old tools cleaned up
Oh, and I've put my hand it the solution many times with no ill affect at all. I think it is because it is producing a DC current, but I could be wrong.
Hey again
I suppose one's natural instinct is not to "put your fingers in the plug" but, after consideration you may well be right. Time to experiment so watch this space
