Introduction: Restoring a Rare Hand Plane | Stanley #4 1/2
Picture of Restoring a Rare Hand Plane | Stanley #4 1/2
I restored my grandfather's old 1885 Stanley 4 1/2 hand plane.
------Follow Us On Instagram------ https://goo.gl/NL6VxS
------Patreon Page THANKS!------ https://www.patreon.com/Woodbrew
----Products used----
WD40 Industrial Strength Degreaser: http://amzn.to/2xg7qUW
Rust Remover Soak: http://amzn.to/2xg7qUW
Diamond Sharpening Stones: http://amzn.to/2iiQ0EE
Buffing compound: http://amzn.to/2iiQ0EE
Leather Strop: http://amzn.to/2iiQ0EE
Super Glue: http://amzn.to/2iiQ0EE
Glue Activator Spray: http://amzn.to/2iiQ0EE
------Our favorite tools!------
Router: http://amzn.to/2q8jmHo
Nail gun: http://amzn.to/2q8jmHo
Jig Saw: http://amzn.to/2q8jmHo
Track saw: http://amzn.to/2q8jmHo
Drill and driver: http://amzn.to/2q8jmHo
Miter saw: http://amzn.to/2q8jmHo
Drill Press: http://amzn.to/2q8jmHo
DeWalt Sander: http://amzn.to/2q8jmHo
--------Camera / Editing Gear--------
Panasonic Lumix G85: http://amzn.to/2hQDYCd
Lumix 25mm 1.7 Lens: http://amzn.to/2hQDYCd
Zhiyun Crane Gimbal: http://amzn.to/2hQDYCd
Rhode Video Mic Pro: http://amzn.to/2hQDYCd
LED Light: http://amzn.to/2hQDYCd
Tripod: http://amzn.to/2hQDYCd
Editing Software package: http://amzn.to/2hQDYCd
Step 1: Disassemble
Picture of Disassemble
Disassemble your hand plane and make sure not to loose any parts.
Step 2: Degrease
Picture of Degrease
Degrease all of the parts. I used this product ( http://amzn.to/2xg7qUW ) to spray on and scrub off with a wire brush.
Step 3: Rust Removal
Picture of Rust Removal
Place all of the steel parts in a sealed container. You will want to use something to raise the parts up off the bottom. We used nuts and this allowed the solution to remove the rust from the underside of parts. Pour in a rust remover product ( http://amzn.to/2uWk7Y7 ) and let the parts soak overnight. To speed up the process you can periodically scrub the parts with a wire brush and place them back in the rust remover.
Step 4: Flatten Plane Sole
Picture of Flatten Plane Sole
Use sandpaper and a flat surface to flatten the bottom of the hand plane sole. I chose to flatten the sides as well, but this is not necessary. 400 grit is a good place to start and finish with 800-1000 grit.
Step 5: Paint
Picture of Paint
If the original paint has worn off, now is a good time to re paint. Use painters tape to mask off any areas you don't want paint. I used a spray can of black semigloss paint.
Step 6: Polish
Picture of Polish
Polish all of the other small parts. I used a Dremel and buffing compound. This will really bring the shine out on any brass parts.
Step 7: Sharpen the Blade
Picture of Sharpen the Blade
Use your preferred method of sharpening to sharpen the iron. I used this diamond stone to sharpen http://amzn.to/2iiQ0EE
Step 8: Fix Handle
Picture of Fix Handle
If either handle is broken you can either fix them or create a new one all together. I chose to glue the handle pieces back together and sand them flush. I used this glue http://amzn.to/2vsGrpp
Step 9: Re Assemble
Picture of Re Assemble
Take all of the pieces and put the hand plane back together. Adjust the blade to barely stick through the bottom of the sole and make sure it is parallel to the plane sole. Lubricate any moving parts with some 3in1 oil.
Step 10: Done!
Picture of Done!
Time to make some shavings! Your all done!
Stu Russell (author)2017-09-24
Blue Ox in Eureka, California is a working museum for vintage human powered saws, drills, etc. The Smithsonian said its the best collection in the country and tried to buy it. The owner wouldn't sell it. If he did it would gather dust with few people seeing it. It is fantastic, you can walk around, watch the tools being used and talk to the operators.
I MP (author)2017-09-14
For a biodegradable rust remover use cosmetic grade citric acid to soak the rusty parts then use a nylon bristle brush to remove the loose rust particles. I use wet and dry sandpaper sprayed with window cleaner (thank you Paul Sellers) attached to a one foot square of counter top granite from Home Depot to true and sharpen the plane parts.When cleaning things up make sure the cap iron has a true edge. For a scary sharp plane iron finish with 2000 grit wet and dry then hone rh blade on a leather strop. I have restored multiple Stanly all metal planes and Bailey iron wooden bodied transition planes. In my opinion no currently available commercial plane will match the work you can do with a restored plane. Old chisels can also be found and resurrected from the dead to fill that void in your workshop.
BetsyFartBlossom (author)I MP2017-09-14
Really, you can restore chisels? Please, tell me how. I have a bunch of old rusty ones that I got from estate sales. I love them all. A lot of people don't know that the tools, shovels, hoes, etc., that you buy from the store aren't sharpened. You have to sharpen them to get them to work right. And, a good chisel will do that. I need to resurrect mine, please, How?
I MP (author)BetsyFartBlossom2017-09-15
Chisels are cutting tools, primarily used on wood but other types of chisels are used on other materials. Restoring a wood chisel is a multi step process from removing the rust to making the chisel true again, sharpening the chisel and the replacing or restoring any damaged or missing handles.Most older ones you will find have suffered some degree of misuse or abuse which will need correction before you being the restoration process itself.
The steps in the process are similar to restoring and sharpening a plane iron. I do not think that the comment section is the place to take up space to describe them. I do not know the Instructables policy on using specific emails but if it is allowed I can write up the entire process and steps as an electronic file and share it with anyone who is interested.
Marais6 (author)2017-09-04
I bought one of these, in perfect condition, except for some rust, at a yard or estate sale. I bought it because the functionality, (which I didn't completely understand, but knew it was some sort of planer) and the beauty of it's form. Now I'm very glad I did. "Friends" are always making fun of me for having old Alpine Sunbeam camshafts and tools like this as decor, but tough 3456. You've shown me a way to perhaps restore it to functionality. I wish I had some real tools, though, but this is so beautiful and the work you did on it is beautiful. Thank you for enlightening me. Thank you for the lesson!!!
BetsyFartBlossom (author)Marais62017-09-14
Hooray! Another estate/yard sale old tool lover. I love to think about who might have used it, what they made and how the recipient loved getting it. Some planes are so beautiful in their style. I like to watch the New Yankee Woodworker and especially The Woodwright's Shop withRoy Underhill. That guy cracks me up. He always has interesting guests, learns stuff, teaches stuff and seems like a really nice guy.
BetsyFartBlossom (author)2017-09-14
Oh! I'm so excited about this! For some reason I love planes! I buy them at estate sales and have all sizes and brands. Of course, most of them are unusable because they are a mess, but now, NOW! I can clean them up and fix them! I am so geeked to get started. I love tools. My brothers can't understand why their sister is so enamored with tools, all tools. I love ladders, too. The older the better:) Thanks for these directions, I'm going to get to fixing my planes this week - or next - depends:)
Chey505 (author)2017-09-14
I buy old tools because I love the design and the made-by-hand history behind them, so to speak. Thank you for sharing the tutorial on restoration. Very helpful and inspiring. Time for me now to gather what I need to work on putting these tools - the planers are my favorite - back to work. :) Thanks, again.
gm280 (author)2017-09-03
Very nice job. Restoring older hand tools to their original finish and being usable again is its own reward.
About This Instructable
5,539views
77favorites
License:
Bio: Hey! This is Molly and Dylan from the YouTube Channel Woodbrew:) We are 20 year old makers, entrepreneurs, and content creators. Happy building!
More by Woodbrew:DIY Giant Polaroid Picture FrameDIY Modern Curved Plywood Lounger ChairRound Dining Table Build With Only $300 in Tools and Materials
Add instructable to:
