Step 11Step 3 Replacing front glass
1) Heat up the Glass and Plastic frame ( I can't really say how long depending on what you use, but a good sign is if you start to smell a little bit of plastic, that's a good signt
2) Someohow, either using your fingers or a prying tool, remove the glass/touchscreen from the frame. This will probably crack the lcd, and actually that makes it a bit easier. I heard from a friend, that if you already have a cracked glass, removing it is a bit easier than trying to remove it as an entire piece. (First pic)
3) Clean off all the old residue, and if you bent your frame alittle, bend it back in to shape.
4) Apply the new adhesive strips ( pretty easy ) make sure that you when you buy the touchscreen/glass it comes with two new strips
5) Before you apply the touchscreen/glass put on some latex gloves ( from now until you are finish) and peel the inside screen protector away a bit, and tape down the cables (second pic)
6)Remove the adhesive from the two strips and place the new glass on your plastic frame (take your time )
Add Comment
